ls bored to 84mm
Old Nov 13, 2007 | 07:53 AM
crxsteve's Avatar
Default ls bored to 84mm
rite now i have a b18a1 boosted on 5 psi
i am gettin ready to build a b18b with rods and pistons i wunt to go b20 pistons
but i wunted to kno how much boost will the sleeves hold up to.. and should i go with a block gurd???? i also have a b16 head with springs and retainers
thanks for the help i don't plan on builden this motor intill i get all the infostraight
Old Nov 13, 2007 | 07:58 AM
morgan@synapse motorsport's Avatar
Default Re: ls bored to 84mm (crxsteve)
you cant bore stock b18 sleeves to 84mm. you would need to sleeve the motor.
Old Nov 13, 2007 | 08:20 AM
bigbadboy's Avatar
what he said. plus using stock pistons and rods is like re-using a condom
Old Nov 13, 2007 | 02:18 PM
crxsteve's Avatar
Default Re: ls bored to 84mm (mike@synapse motorsport)
i was always told you could bored a ls to 84mm
i am plaining on getin turbo pistons and rods
i am don't plan on building this intill i get all my info straight thats why i am on here askin
Old Nov 13, 2007 | 02:26 PM
Schister66's Avatar
Man U FTW
the biggest you can go on a stock sleeve LS is 81.5mm. If you run aftermarket sleeves, you can go 84mm
Old Nov 13, 2007 | 02:34 PM
A.E Motoring's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">the biggest you can go on a stock sleeve LS is 81.5mm. If you run aftermarket sleeves, you can go 84mm</TD></TR></TABLE>
Old Nov 13, 2007 | 02:40 PM
CerealKiller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsteve &raquo;</TD></TR><TR><TD CLASS="quote">rite now i have a b18a1 boosted on 5 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">you cant bore stock b18 sleeves to 84mm. you would need to sleeve the motor.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">what he said. plus using stock pistons and rods is like re-using a condom</TD></TR></TABLE>
blackeg's Avatar
Default Re: (Dual Cam Racing)
lol thats gross.
i wouldnt go over 81.5mm on a stock sleeve, you can go up in the 85mm range on most sleeved motors, depending on if you o ringed or not
Old Nov 13, 2007 | 02:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsteve &raquo;</TD></TR><TR><TD CLASS="quote">i was always told you could bored a ls to 84mm
Who have you been listening to?
Old Nov 13, 2007 | 02:56 PM
Schister66's Avatar
Man U FTW
The person who told you this information may have failed to mention that you must get aftermarket sleeves for that size bore...its not a huge deal.
TDogg Teg's Avatar
What is your horsepower goal? If you have a high goal, I suggest you sleeve the block (and as Schister stated, youre gonna have to anyway, if you go up to 84mm).
5 to 10 psi on an ls/vtec setup like youre about to do will be fine with an 81.5mm bore and aftermarket pistons/rods and a good tune. But when you start puttin some REAL boost to that B18 block, youre gonna put some real stress on the block with that B16 head spinning that much RPM on the stock sleeves due to the LS's 1.54:1 rod-to-stroke ratio.
Sleeve the block, so you can do your 84mm bore. Its the best insurance you can have for your motor. Remember, its all about your horsepower goal, and what you wanna get out of your setup.
Old Nov 13, 2007 | 04:36 PM
blinx9900's Avatar
LIES!! to the op: DO IT!!!!
Jm98ek
Engine Machining & Assembly
Apr 16, 2018 02:51 AM
ekVtecPower
14
Jan 19, 2018 09:04 PM
TravisBiggie
Apr 22, 2013 04:46 AM
spoonzdelsol
12
Aug 7, 2005 08:13 PM
AccordDX89
Mar 2, 2005 05:22 PM
