Fuel management
Old Nov 10, 2007 | 01:23 PM
roachsboosted16's Avatar
Default Fuel management
im on a limited budget right now, so shude i spend the $100 for the fmu or save for a month for the piggyback unit/ replacement ecu?
Are fmus dangerous to use? i hear alot of complaints about them
Old Nov 10, 2007 | 01:41 PM
Boostud's Avatar
Default Re: Fuel management (roachsboosted16)
Save for a month or however long it takes.
Old Nov 10, 2007 | 02:08 PM
Old Nov 10, 2007 | 02:33 PM
fuel management unit, or ecu?
Old Nov 10, 2007 | 02:36 PM
Boostud's Avatar
ECU sorry for the lack of clarity.
Old Nov 10, 2007 | 02:39 PM
sorry if i dont accept right away, i need more than one opinion before i make a serious decision.
Old Nov 10, 2007 | 03:09 PM
bump it up
Old Nov 10, 2007 | 03:36 PM
DeadVet's Avatar
What are you trying to tune? FMU is only asking for trouble....Id opt for something like crome or uberdata.
Old Nov 10, 2007 | 03:48 PM
i only need a unit for fuel/air. ive been looking at blox fmu, and i can get a 12:1 and evry 1 psi it lowers the compression accordingly. that or somethin like hondata/e-manage for the same purpose.
Old Nov 10, 2007 | 03:58 PM
DeadVet's Avatar
But why waste the money? Just find someone on here in your area that tunes with crome or uberdata and be done with it. Dont try to be cheap and end up having it run like **** or worst case blow up.....Do it right the first time.
Old Nov 10, 2007 | 04:00 PM
Default Re: Fuel management (1TurboHatch)
ther is not a tuning shop close enough to make runs to the shop like that. i need something that will self adjust the compression and that i can work on.
Old Nov 10, 2007 | 04:28 PM
base-op.1320's Avatar
A 12:1 fmu raises the fuel pressure 12 psi for every pound of boost. You can't run very much boost with a fmu cause your fuel pressure will rise to very high pressures making your injectors spray funny. And if you are running boost then you most likely are going to want to adjust your ignition timing to keep it safe. Get yourself injectors, an emulator, socketed p28 ecu, crome, and someone that knows how to tune it.
Modified by base-op.1320 at 9:14 PM 11/10/2007
Old Nov 10, 2007 | 04:35 PM
Default Re: Fuel management (base-op.1320)
thank you. would it be good for up to 10psi? not as easy fix as i thought it would be.
Old Nov 10, 2007 | 04:43 PM
DeadVet's Avatar
Its not safe at all IMO. It might blow up or you might get lucky and have it only run like ****.
Crome and uberdata are free. Do some research on tuning and buy a used wideband and be much happier in the end.
Old Nov 10, 2007 | 06:25 PM
mtber's Avatar
http://www.phearable.net/tech/....html will answer your questions.
Old Nov 10, 2007 | 06:34 PM
reboosted's Avatar
Default Re: Fuel management (mtber)
save your money, fmu is a bad choice
Old Nov 10, 2007 | 08:11 PM
Default Re: Fuel management (reboosted)
yeah a fmu at 10 psi would be about 160 psi of fuel pressure, which is 120 psi to much
Old Nov 11, 2007 | 07:07 AM
dbiker207's Avatar
fmu sucks, get crome or somthing like it.
gsr_pimp88
Oct 27, 2006 08:25 PM
hoskos
Jan 21, 2006 05:57 PM
salman
Apr 11, 2005 05:40 PM
wpgcivic
Jul 7, 2004 05:45 AM
avividmemory
Aug 21, 2002 08:36 AM
