how much more boost?
Old Nov 15, 2007 | 02:51 PM
eboostjr's Avatar
Default how much more boost?
Car was recieved w/a b20vtec, b16 head w/gsr cams and springs, stock valves, t3/t4 turbo, do not know trim on turbo find out later, has built bottom end(pistons and rods) at 9.0:1, stock sleeves . Car is street tune at 10 psi on pump 91, pulled like a raped ape at top end( from about 5800). I've seen a stock b20b at 15 psi, but could not find much more on this.
Old Nov 15, 2007 | 04:39 PM
JaredKaragen's Avatar
Default Re: how much more boost? (eboostjr)
your tune will let you know... tune slowly higher till you begin to hit "the wall";
OEM sleves can take a bit if properly tuned and built.
Old Nov 15, 2007 | 04:55 PM
bnut510's Avatar
Default Re: how much more boost? (JaredKaragen)
particularly.. how much can a b20 take on oem sleeves before blowing? on a standard t3/t4 .60trim or so? just curious because i hear different opinions... but more that lean toward the fact that b20 sleeves just dont hold up as well as the b16 or b18.
Old Nov 15, 2007 | 06:07 PM
hmongxcuz's Avatar
i wouldn't turbo a b20 till i sleeve it.
Old Nov 15, 2007 | 07:43 PM
fmfkid250's Avatar
wow seems to be all the people who hit these threads up dont even bother anymore....
10psi really doesent mean anything its about the CFM's but to answer your question yes b20s can handle 15psi with a proper tune and not being stupid with it. theres a local kid that was almost at 500whp with a Bone stock b16 bottem end
Stock sleeves handle up to an beyond 600whp with a proper tune and a well built engine
Old Nov 15, 2007 | 07:46 PM
HAMOTORSPORTS's Avatar
Default Re: (fmfkid250)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 &raquo;</TD></TR><TR><TD CLASS="quote">wow seems to be all the people who hit these threads up dont even bother anymore....
Stock sleeves handle up to an beyond 600whp with a proper tune and a well built engine</TD></TR></TABLE>
remember, b20 sleeves are much thinner than b16's
I wouldn't push the envelope until sleeved - better safe than sorry
Old Nov 15, 2007 | 07:55 PM
bigbadboy's Avatar
350 is a good safe spot. if the tune is well enought i would go with 450. my friend also has a stock B20-V and he is making over 350 and hasn't had any problems out of it
Old Nov 15, 2007 | 08:24 PM
HiProfile's Avatar
Default Re: (bigbadboy)
People have hit 600whp with stock B18 sleeves, while others have cracked 81mm sleeves at 300whp. Its all in the tuning, gasoline, cooling system, and driver. If any one of those is bad at any point, boom.
Old Nov 15, 2007 | 08:38 PM
Fat Head
Guest
Posts: n/a
Default Re: how much more boost? (bnut510)
how much hp dose it have?
Old Nov 15, 2007 | 09:31 PM
eboostjr's Avatar
Default Re: how much more boost? (Fat Head)
^^^^ dont know, its just has a street tune
Old Nov 15, 2007 | 09:35 PM
eboostjr's Avatar
sorry about leaning only on psi, which I know 11 psi on a gt 42r is not the same as a 16g turbo, just slip when I was writing the original post, thanks for all the positive comments, helps a lots
Old Nov 17, 2007 | 04:21 PM
eboostjr's Avatar
Default Re: (eboostjr)
Once I get a 3bar map sensor, I will go for a 17 pound street tune, which clutch should I go for, I was thinking of stage 3 from clutchmasters
Old Nov 17, 2007 | 06:10 PM
Eklsv-t's Avatar
im r unning stage 3 from clutchmaster,not bad, but harsh dd
Old Nov 19, 2007 | 03:51 PM
eboostjr's Avatar
Default Re: (Eklsv-t)
I got a deal on a sc 61, dont know the trim, but is it better than the t3/t4 57 trim I already have. I am trying to push for 450 hp w/a great tune . This build is going for drag, I dont mind if a lil laggy.
Looking for 11's
sepetinswenze
Dec 2, 2006 06:04 PM
b18_racer805
Sep 26, 2006 09:02 PM
Ben Ogle
Aug 19, 2006 10:17 PM
exare250
Feb 22, 2006 09:31 PM
TwistedHatch
Apr 21, 2003 11:44 AM
