breaking in the motor
Old Nov 15, 2007 | 08:49 AM
1993gsrcivic's Avatar
Default breaking in the motor
ok i am in the process of rebuilding my gsr and i know when it goes back in i got to break in the motor and i want to boost but not right away so i was wondering what is a good compression ratio piston to get i know stock gsr is like 10:1 or 10.6:1 but lower compression is better 4 turbo right?
what kind of oil pump should i got gsr or typr r?
and what type of piston?
(i have eagle rods so i know oem piston wont fit )
Old Nov 15, 2007 | 08:59 AM
tony413's Avatar
Default Re: breaking in the motor (1993gsrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993gsrcivic &raquo;</TD></TR><TR><TD CLASS="quote">ok i am in the process of rebuilding my gsr and i know when it goes back in i got to break in the motor and i want to boost but not right away so i was wondering what is a good compression ratio piston to get i know stock gsr is like 10:1 or 10.6:1 but lower compression is better 4 turbo right?
GS-R and Type-R are the same oil pump
9:1 - 10:1 is ok but the higher the comp. the more heat you make and increase the chance of detonation. so pick a fair trade off like 9.5:1 or 9.7:1
Old Nov 15, 2007 | 09:06 AM
agrn93ls's Avatar
Default Re: breaking in the motor (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
Funny thing about that, i have bought two oil pumps from the dealer, two Type-R pumps, the first time i thought they made a mistake but same thing the second time, the Type R pump cost about 60$ less. the GSR pump and LS pump are the exact same price to the penny around 170 and the Type R was like 106 or something.
so cliff notes, get the Typer R save some cash.
Old Nov 15, 2007 | 09:07 AM
Schister66's Avatar
Man U FTW
Your goals will determine your piston choice. Lower compression is going to allow you to run more boost on a lower grade fuel, BUT will adversely affect acceleration.
Higher compression will be more responsive off boost, but limits what you can make on a certain grade fuel.
What are your specific goals??
Old Nov 15, 2007 | 09:08 AM
Default Re: breaking in the motor (agrn93ls)
my goal is like 300whp daily driver i really dont know much about boost i was going 2 spray my motor but have changed my mind
Modified by 1993gsrcivic at 1:31 PM 11/15/2007
Old Nov 15, 2007 | 09:09 AM
i thought one oil pump flowed better than the other well thanks
and whats a good tranny for boost i was thinking a type r but i know some ppl say a longer tranny is better 4 boost like a ls and some say shourter one is better like a gsr /b16
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls &raquo;</TD></TR><TR><TD CLASS="quote">
so cliff notes, get the Typer R save some cash. </TD></TR></TABLE>
they charged you different prices for the same part as long as it has 22t your golden
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993gsrcivic &raquo;</TD></TR><TR><TD CLASS="quote">i thought one oil pump flowed better than the other well thanks
and whats a good tranny for boost i was thinking a type r but i know some ppl say a longer tranny is better 4 boost like a ls and some say shourter one is better like a gsr /b16</TD></TR></TABLE>
drivers pref. what are you personally wanting to use the tranny for drag, street, or track, or DD
Old Nov 15, 2007 | 09:12 AM
agrn93ls's Avatar
they charged you different prices for the same part as long as it has 22t your golden </TD></TR></TABLE>
i dont care if they did, they charged me 60$ less. i didnt buy the gsr i bought the R
22t oil pump? are you talking about the water pump? didtn know if you were referring to pump gear or drive gear.
Old Nov 15, 2007 | 09:17 AM
Schister66's Avatar
Man U FTW
If you're ONLY looking for around 300whp, you can make that on the stock block. Save your money from the engine build and put it towards a better setup, or better yet, a great EMS and tune.
If all you want is 300whp, that can easily be accomplished on stock...check my sig. That's on a stock GSR block. I boosted it at 52,xxx miles and now i'm around 72,xxx after 2 years.
Old Nov 15, 2007 | 09:19 AM
tony413's Avatar
22t oil pump? are you talking about the water pump? didtn know if you were referring to pump gear or drive gear.</TD></TR></TABLE>
haha wow ADHD owns me 22t is for a water pump
Old Nov 15, 2007 | 09:20 AM
agrn93ls's Avatar
haha wow ADHD owns me 22t is for a water pump </TD></TR></TABLE>
"IDIOT........ GOSH" jk man
Old Nov 15, 2007 | 09:27 AM
i already have everything 4 my motor (eagle rods, balenced crank,gaskets and water pump) i only need the oil pump and the pistons and i need to get the bolck hot tanked and honed then my bottom end is done
Old Nov 15, 2007 | 09:32 AM
whats a good piston? (brand)
whats a good tranny?
Old Nov 15, 2007 | 10:06 AM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993gsrcivic &raquo;</TD></TR><TR><TD CLASS="quote">whats a good piston? (brand)
and whats some good things to do to the head</TD></TR></TABLE>
start by reading this first http://www.evans-tuning.com/te....html
Old Nov 15, 2007 | 10:13 AM
Schister66's Avatar
Man U FTW
If Evans recommends CP, then i'm getting CP. Although that was my preference from the start. I dont think i've heard a bad thing about them yet...
Old Nov 15, 2007 | 10:16 AM
tony413's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">If Evans recommends CP, then i'm getting CP. Although that was my preference from the start. I dont think i've heard a bad thing about them yet...</TD></TR></TABLE>
im a wiseco fan but yeah CP is known for there shelf tolerances.
NOT BASHING!!! there was a point when some of the older CP's had problems with chipping the valve relief area because of a design mishap, but its fixed now.
Old Nov 15, 2007 | 10:17 AM
thanks for the evans i will read over everything then ask more question
Old Nov 15, 2007 | 12:06 PM
agrn93ls's Avatar
Default Re: (tony413)
NOT BASHING!!! there was a point when some of the older CP's had problems with chipping the valve relief area because of a design mishap, but its fixed now. </TD></TR></TABLE>
BIG wiseco fan here
X2 on the above statement. i like wiseco and CP the most, only concern with CP was the valve relief issue that seems to have been resolved.
Old Nov 15, 2007 | 12:11 PM
Schister66's Avatar
Man U FTW
Default Re: (agrn93ls)
BIG wiseco fan here
X2 on the above statement. i like wiseco and CP the most, only concern with CP was the valve relief issue that seems to have been resolved.</TD></TR></TABLE>
CP and Wiseco are the two companies i would go with without any hesitation. My buddy Brandon uses them religiously in any D series work he does and to my knowledge hasn't had any problems with them.
Old Nov 15, 2007 | 02:26 PM
got wide's Avatar
has anybody heard anything bad about JE's
Old Nov 15, 2007 | 07:45 PM
Default Re: (got wide)
so what kind of tranny you ppl using
Old Nov 15, 2007 | 07:51 PM
SpoolnG2's Avatar
Default Re: (1993gsrcivic)
Use CP pistons with a 9:1 c/r. Then get a B16 or Type R trans. Preferably something with a LSD. Longer gears are definately not better for boosting. Hope this helps.
Old Nov 15, 2007 | 08:44 PM
Schister66's Avatar
Man U FTW
B16 trannies are annoying IMO...i would get either a GSR or ITR tranny. Stock LSD's are nice, but aftermarket Quaifes are much much better
Old Nov 16, 2007 | 11:25 AM
i got a gsr tranny now wit no lsd
so should i get get this one rebuilt and add a lsd and maybe a type r final
or just get a brand new type r
Old Nov 16, 2007 | 12:16 PM
Schister66's Avatar
Man U FTW
get a Quaife put in the one you have now and leave it alone otherwise...
