JRSC Engine Build Help/Advice needed
Old Nov 10, 2007 | 06:20 PM
Schrader's Avatar
Default JRSC Engine Build Help/Advice needed
Well the winters here, and its time to start rebuilding the B18C1
Next spring a JRSC will be going on at 10-12 psi. I Already have a good idea of what needs to be done But if anyone wants to put up a list of what they would do to Build a bullet proof engine. Be My Guest
Old Nov 10, 2007 | 07:05 PM
rmcdaniels's Avatar
Default Re: JRSC Engine Build Help/Advice needed (Schrader)
10.5:1 pistons, oversized exhaust valves, GSR-I+ITR-E cams, LHT Intercooler, blower porting, the usual stuff.
Old Nov 11, 2007 | 05:17 PM
Schrader's Avatar
Default Re: JRSC Engine Build Help/Advice needed (rmcdaniels)
And which pistons would you recommend?
Old Nov 11, 2007 | 05:26 PM
B18MOBBER's Avatar
im bulding the same right now and no one can give me answers. any help appreciated.
Old Nov 11, 2007 | 05:42 PM
rmcdaniels's Avatar
Ordinarily Wiseco, but last time I ordered a set of Wisecos they took 6 months and made nothing. I tried JE and they had them in a couple of weeks. That's for custom pistons though, if you find some place with a set of Wisecos in stock then go for it. Check -w- Race Engineering, they usually stock a good selection of pistons.
Old Nov 11, 2007 | 06:16 PM
B18MOBBER's Avatar
now what are you guys using as far as ecu program.
i have:
AEM UEGO so its very precise on what i want. what do i do for program
Old Nov 11, 2007 | 07:03 PM
allmotor89hf's Avatar
I run Mahle's in mine. For EMS, I run an s100
Old Nov 12, 2007 | 07:34 AM
rmcdaniels's Avatar
Default Re: JRSC Engine Build Help/Advice needed (B18MOBBER)
I use an AEM EMS, but that's overkill for most setups. Some type of Chipped ECU like Hondata, Crome, etc, should be fine.
Old Nov 12, 2007 | 11:22 AM
Schrader's Avatar
Well other then getting custom Pistons built they don't seem to offer a Piston in the 10.5:1 ratio. Or is there something that I am missing?
Old Nov 12, 2007 | 02:27 PM
B18MOBBER's Avatar
so i can use crome and how do i get the right set up?
Modified by B18MOBBER at 10:09 PM 11/16/2007
JDMCRX
Jan 17, 2011 05:02 PM
cnydc2
May 22, 2009 02:01 PM
highflyinhonda
Apr 21, 2009 07:30 AM
preludecus
Feb 15, 2004 07:13 PM
