i have a 99 honda civic si with a b16a that i plan to turbo and run between 5 to 8 psi
i am going to run e manage and i was wondering if i need to change the fuel injectors or anything else to be safe
Re: i have a 99 honda civic si with a b16a that i plan to turbo and run between 5 to 8 psi (vegeta)
if you want to be safe...
Convert to odb1 and get it tuned w/ crome or hondata
you'll need some injectors as well as a fuel pump...
550s would be plenty... or you could get soem dsm 450's
Walbro 255LPH fuel pump would be best.
Man U FTW
I would get a chipped OBD1 ecu, 550cc injectors and get that setup tuned. That way you dont limit yourself to ~220whp. You can make a lot more than that with a good setup and good tune. Check my sig...those #'s are on a stock GSR block (2 years strong)
Re: (Schister66)
also i bought a greddy e manage and it came with japanese instructions.my question is when i hook up the e manage and use the support tool will it be in japanese or english.
