Blox cams vs skunk2 pro cams (for turbo H22)
which one is better for a H22 turbo setup?
blox type A or B?
or
skunk2 pro series 1?
it's gonna be a fully built engine.
thanks
blox type A or B?
or
thanks
Re: Blox cams vs skunk2 pro cams (Mr Aryan)
these are the profiles i found.
blox type A = not available on their website!!
blox type B:
Intake (lift / duration) 12.8mm / 272
Exhaust (lift / duration) 11.9mm / 280
skunk2 pro series 1:
Intake: 264°/12.6 @ 1mm / 0.000” lash
Exhaust: 264°/11.9 @ 1mm / 0.000” lash
blox type B:
Blox cheap junk that might do the trick, comparing to Skunk with a good reputation, IMO get the skunk instead of the junk..
ahln bweld elbhrain..
mostly depend what setup r u using? i saw some use the stock cams for over 400hp and its good for them?
u can use the stock cams for 500hp i guess
my opinion use the skunk2 pro 1 its better for both turbo and nonturbo
i talk with skunk2 befor about the cams and wich better cams for turbo and they tell me about the pro1.
idont know much about blox cams..
