valve adjustment?
Old Nov 13, 2007 | 11:33 PM
mma82's Avatar
Default valve adjustment?
at about what mileage should the valves be adjusted? 50 some thousand? does it matter from usdm to jdm on gsr motor?
Old Nov 13, 2007 | 11:51 PM
tony413's Avatar
Default Re: valve adjustment? (mma82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mma82 &raquo;</TD></TR><TR><TD CLASS="quote">at about what mileage should the valves be adjusted? 50 some thousand? does it matter from usdm to jdm on gsr motor?</TD></TR></TABLE>
just check them first. what pistons and valves are you using ? stock ?
Old Nov 13, 2007 | 11:55 PM
mma82's Avatar
yea the stock jdm b18c pistons and valves. the valves seem like they are ticking louder than they use too
Old Nov 14, 2007 | 12:21 AM
tony413's Avatar
get some feeler gauges and check the tolerance
russianswty
Oct 22, 2006 06:15 AM
Baron55
Aug 9, 2005 03:27 PM
cxSHOE
Mar 29, 2004 05:20 PM
^jefs0ng
Dec 9, 2003 06:48 PM
miksew
Aug 26, 2003 11:16 PM
