built 2.0 gsr need help
Old Nov 17, 2007 | 02:45 PM
builtturboeg's Avatar
Default built 2.0 gsr need help
need help i just put a built 2.0 gsr in my car motor is 84mm sleeved block with rods/pistons 9:1 comp and a p&p head with skunk 2 valves/springs/retainers gsr cams with camgears ok heres where i need help went to fire it up and it started right up but did not sound right so i shut it off and checked timing and the exhaust camgear was retarded -8 deg so im scared to start it now that i set it to 0 what to do ??????????
please help!!!!!!!!!!!!
Old Nov 17, 2007 | 02:50 PM
Maxcapacity's Avatar
Default Re: built 2.0 gsr need help (builtturboeg)
Start it back up with timing gun in hand, and ready to go.
Old Nov 17, 2007 | 02:53 PM
mtber's Avatar
Skunk2 camgears usually do not come with the adjustment bolts torqued down.
Set everything to Top Dead Center & perform a leakdown/compression test to see if you bent/damaged anything. You may even want to consider pulling the head to ensure you didn't make any contact between piston/valve valve/vale but I doubt you did.
Old Nov 17, 2007 | 03:18 PM
thanks for the help my dumb *** was like a kid in a candy store just couldent wait to start it
Old Nov 17, 2007 | 10:35 PM
D@nnY's Avatar
Default Re: (builtturboeg)
if the valves are bent or motor is off timing the compression test number will be very low
jdmb16turbo
Jan 5, 2009 04:23 PM
.doeboyfresh.
Jul 14, 2006 09:03 PM
Type_gsR
Jul 25, 2003 02:03 PM
