Blow Off Valve Problems
Old Mar 2, 2008 | 05:17 PM
youdontneed2cams's Avatar
Default Blow Off Valve Problems
I have an knock off greddy blow off valve and at about 6 psi when i shift i hear half compressor surge and half blow off, what could be causing this all my vac lines are clamped down so i know its not a leak, any ideas?
Old Mar 2, 2008 | 05:35 PM
nam3less's Avatar
Default Re: Blow Off Valve Problems (youdontneed2cams)
Yes... the answer lies on the first 9 words of your statement.
Old Mar 2, 2008 | 05:44 PM
ok anyone have a serious answer? not sarcastic bullshit?
Old Mar 2, 2008 | 07:01 PM
blinx9900's Avatar
Default Re: (youdontneed2cams)
if its a knock off RS i can tell you this much, my REAL rs dosent even work so i dont expect a knock off rs to work...
however you can try loosening the bov, just dont loosen it to the point it wont hold boost, your gonna have to make some adjustments, make a pass with your eye on the boost gauge and repeat until you get the desired results. taking the inner spring out may also cure your issue, it didnt help me but it does help some people.
Old Mar 2, 2008 | 07:34 PM
ok ill try that thanks alot
Old Mar 2, 2008 | 07:36 PM
da_dude's Avatar
I had use a knock off greddy rs bov before. I can tell you that you will need to open it up and take either the inner or outter spring out. If you don't do this you'll most likely have compressor surge. Heck, even the real greddy RS bov I had to take one of the spring out too otherwise I'll have compressor surge too.
Old Mar 2, 2008 | 08:37 PM
blinx9900's Avatar
Default Re: (da_dude)
thats cause teh RS stands for really sucky bov...
Old Mar 2, 2008 | 08:43 PM
any suggestions on what to replace it with, because i know i will eventually
Old Mar 2, 2008 | 09:44 PM
da_dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youdontneed2cams &raquo;</TD></TR><TR><TD CLASS="quote">any suggestions on what to replace it with, because i know i will eventually</TD></TR></TABLE>
If you are looking to use the same flange than the greddy type s is a good bov. I like it alot but sadly sold it a few years back. Otherwise a HKS or Tial.
Old Mar 2, 2008 | 10:12 PM
blinx9900's Avatar
type S is discontinued, im personally buying a Tial next.
TravisBiggie
Apr 20, 2012 11:03 AM
jacob4lester
Feb 15, 2010 05:30 PM
94c1v1cex
Sep 4, 2007 11:09 AM
ragethemachine86
Sep 12, 2006 08:07 PM
CivicMike
Jun 7, 2005 10:58 AM
