B20 SWAP
Old Mar 5, 2008 | 06:14 AM
juanchoenuncrx's Avatar
* B A N N E D *
Default B20 SWAP
WHAT CAN I GET OUT OF A B20 ENGINE IS NOT VTEC . so most people use it to boost it cuase all motor i dont think it has that much hp so please give me some advice to see which it will be beter b18 on boost or b20 on boost for my crx?
Old Mar 5, 2008 | 06:44 AM
zccr-xsi's Avatar
well for boost i would pick either b18a1 or dohc zc<<comes with low c/r but has very weak rods.but ive heard samething with b18a they have thin *** rods also.when boosting a stock motor u want to be wise on what u do and buy.
IMO buy a d-series boost it so when u blow it up the motor will be cheap to repalce.
Old Mar 5, 2008 | 07:13 AM
ep4life's Avatar
Default Re: (zccr-xsi)
b18a
either a1 or a2
i put 22 pounds of boost on a completely stock b18a2 the only thing that wasnt stock was the clutch and 880 injectors and s300 we made 320 to the wheels that was a month ago and its still holding
dont let people fool you ls motors are the best motor for boost
Old Mar 5, 2008 | 07:17 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
wrong forum. but i wouldn't waste your time boosting a stock b20. cylinder walls are paper thin.
And if you put 22 psi to any honda motor and only made 320, your tuners a [freak]ing joke or you're lying. I'm going with the 'you're lying' option
Old Mar 5, 2008 | 07:42 AM
zccr-xsi's Avatar
Default Re: (ep4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ep4life &raquo;</TD></TR><TR><TD CLASS="quote">b18a
either a1 or a2
dont let people fool you ls motors are the best motor for boost</TD></TR></TABLE>
anything can surive boost it depnds on how good the tune is!!!!!!!!!!!
Old Mar 5, 2008 | 08:45 AM
ComeOnKip's Avatar
trust me, i'm well aware of the tuning capabilities of the companies out ther, but those numbers don't line up. you can make 320~whp with HALF the boost.... its bullshit dude.
Old Mar 5, 2008 | 09:07 AM
bigbadboy's Avatar
PSI doesn't mean ****. i say boost which ever one you want. i got 2 friends with boosted B20. one is a stock B20 bottom end with a Vtec head making 380. the other is a completely stock b20 making 280. both with about the same PSI. so what does that tell you.
you can go for 300hp realibly as long as your tune is good. if you are real confident about your tuner then take it to 350 but its all up to you. i made 400 on my bone stock LS for about 8 months of straight beating on it. then a rod bolt stretched on me. but i was also revving it to 7700
Old Mar 5, 2008 | 09:21 AM
T9U4ReBgO's Avatar
Default Re: (bigbadboy)
ls can take some abuse that's for sure...myself I have a b20 i just got tuned last night and I had a few problems but it still mad some nice numbers...tq is crazy in it so really its just preference.....Jason u still getting ur monster tuned today??
Old Mar 5, 2008 | 10:02 AM
blwn95civic's Avatar
either a1 or a2
Old Mar 5, 2008 | 11:04 AM
Cm0ney's Avatar
Default Re: (blwn95civic)
if you go b20 go b20b it has a little lower compression then the z. i have had mine on 8 pounds for about 7 to 8 months and so far nothing bad has happened. . plus i dont beat on it all the time but it is my daily driver. but yea i hear all the time about the walls being thin. either way just get it tuned .
Old Mar 16, 2008 | 10:17 AM
fin781's Avatar
how are you going to say he is lying ? when if hes running 22 psi on a smaller turbo, its not going to produce as much power as a bigger turbo, he may be running 22 psi on a t28 where his tune is good, rather than hitting 22 with a gt45 or something along those lines. then i would say he is "lying." but b20s come from ls blocks, there just bored over, ecentially their the same block, bigger bore, thinner walls. sleeve one and you have an awesome platform.
importdays
Nov 11, 2011 11:52 AM
92 hatchback
Mar 19, 2009 12:59 PM
Subterraneous
Aug 26, 2006 07:29 PM
tobe1424
Jul 26, 2005 11:32 AM
turboandbroke
Feb 28, 2004 04:09 AM
