act HC4-XTR4 clutch slippin at only 14-15 psi?? sohc ....
HC4-XTR4 $501.40
Xtreme Pressure Plate
Clamps load increase of 50% to 120%, Pedal feels moderate to stiff, Many SFI Certified to insure safety
Solid Hub (4 Pad) Disc
Recommended for Drag and Road Racing, Increased torque capacity, Fastest shifts, low inertia, Good durability but shortened spline life, Harsh engagement, chatter
350 hp its sayin it good for, i had to lower my boost to about 13 -14 solid to get it to not slip.. only 3000miles on it so far .. i highly doubt at 15 psi im over 350 hp with my stock block single cam... is this normal? what clutch will hold over that for single cam? i need it before mar 22nd? its a t3t4 57 trim
Re: act HC4-XTR4 clutch slippin at only 14-15 psi?? sohc .... (97grnrs)
We use an action 2MD clutch in our setup.. 460+ hp 358 lbs tq with absolutely no slipping what so ever.
Re: act HC4-XTR4 clutch slippin at only 14-15 psi?? sohc .... (Newt Dog)
all i wanna do is run 11's with this setup.. if i can do it on 13-14 psi ill be happy. if not ill get that clutch.. i dunno how much hp i have i never dynoed it.. car is completely gutted crx si.. basically a shell with a motor... so hopefully i can ..
boostincoupe
03-05-2004 09:24 AM
