Do I need to order special O-rings to run with a Edelbrock manifold?
Hey all, I plan on running RC 1000 cc injectors with a AEM fuel rail....do I need special O-rings to run this manifold? Is there anything else I should be aware of that I'll need to order to mount this all together? Thanks
Re: Do I need to order special O-rings to run with a Edelbrock manifold? (champLSinteg)
Hmm, just looks like the ports on it are bigger than the o-rings the injectors come with.
i ♥ my honda
Global Mod
Global Mod
Re: Do I need to order special O-rings to run with a Edelbrock manifold? (totsie7944)
Stock o-rings should work... If they look to small for your injectors you may have gotten DSM injectors. If they look to small for your rail, it might just be your eyes playing tricks on you. Or the rail in question was made for DSM injectors.
Re: Do I need to order special O-rings to run with a Edelbrock manifold? (White Smoke)
Well they are def RC injectors, which come with 0-rings, so I should be ok...just looked liked the Edelbrock manifold itself needed Bosch injectors or something.
