10.6.1 comp?
Old Feb 29, 2008 | 09:01 PM
jordanitr's Avatar
Default 10.6:1 comp?
Is ''10.6:1'' comp to high for boost? This is for a type R motor.
Modified by jordanitr at 3:30 PM 3/2/2008
Old Feb 29, 2008 | 10:59 PM
HondaKyle's Avatar
Default Re: 10.6.1 comp? (jordanitr)
You should be safe with 7-8 PSI
Old Mar 1, 2008 | 07:38 AM
quicksilver1689's Avatar
i ♥ snails
lol ^
Old Mar 1, 2008 | 08:28 AM
HondaKyle's Avatar
Default Re: (quicksilver1689)
Just giving my opinion. Im sorry but I forgot you know every thing
Old Mar 1, 2008 | 08:32 AM
cjordan's Avatar
Default Re: (HondaKyle)
once again PSI really doesnt matter, its all in the tune. A local shop around here just finished an 11 to 1 compression B16 it went up to 16 pounds and made 378whp. They used Hondata S300 for the EMS
Old Mar 1, 2008 | 08:34 AM
JoePSI's Avatar
Default Re: (cjordan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjordan &raquo;</TD></TR><TR><TD CLASS="quote">once again PSI really doesnt matter, its all in the tune. A local shop around here just finished an 11 to 1 compression B16 it went up to 16 pounds and made 378whp. They used Hondata S300 for the EMS</TD></TR></TABLE>
Sorry to thread jack, but do you have a dyno sheet and setup specs of this? I'm curious to see the midrange.
Old Mar 1, 2008 | 10:45 AM
jordanitr's Avatar
Sorry to thread jack, but do you have a dyno sheet and setup specs of this? I'm curious to see the midrange.[/QUOTE]
Me too......
Old Mar 1, 2008 | 12:20 PM
cjordan's Avatar
Default Re: (jordanitr)
naw, i was just at the shop and they were telling me bout it. i know they have building the car for well over a year now. i was shocked as hell myself. i will be up there sometime this week i am sure and ill ask if he has one there.
Old Mar 1, 2008 | 08:08 PM
2point2's Avatar
it's "10.6:1".. it's a ratio.
You'll just have to keep a good eye on things with that kind of compression. There's countless threads if you search.
Old Mar 1, 2008 | 10:54 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjordan &raquo;</TD></TR><TR><TD CLASS="quote">naw, i was just at the shop and they were telling me bout it. i know they have building the car for well over a year now. i was shocked as hell myself. i will be up there sometime this week i am sure and ill ask if he has one there.</TD></TR></TABLE>
type of fuel used??
Old Mar 2, 2008 | 11:42 AM
GS-R Civic's Avatar
Get a good tune, my JDM B18c GSR (10.6:1 as well) was daily driven for 2 years on 7psi and now making 370whp on 14psi noooo problem!
Old Mar 2, 2008 | 12:53 PM
gringotegra's Avatar
Default Re: 10.6.1 comp? (GS-R Civic)
its all in the Tune jordan!!!!
Old Mar 2, 2008 | 12:55 PM
vtec_killer_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-R Civic &raquo;</TD></TR><TR><TD CLASS="quote">Get a good tune, my JDM B18c GSR (10.6:1 as well) was daily driven for 2 years on 7psi and now making 370whp on 14psi noooo problem! </TD></TR></TABLE>
are u on pump gas? did u have to 3 bar map?
hit me back
Old Mar 2, 2008 | 02:27 PM
jordanitr's Avatar
Default Re: 10.6.1 comp? (gringotegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringotegra &raquo;</TD></TR><TR><TD CLASS="quote">its all in the Tune jordan!!!!</TD></TR></TABLE>
Who let you in here?
Old Mar 2, 2008 | 03:59 PM
i have more of a right to be in here than you!!! ... i already told you man...its all in the tune!!! look at the new Z06's they have 11.1 compression ratio's and people are twin turboing them and getting insane numbers!!!...what makes you think you cant turbo your 10.6??
Old Mar 2, 2008 | 04:26 PM
jordanitr's Avatar
com diddley down, I'm just doing research, Effin-ethug
Old Mar 2, 2008 | 04:29 PM
jordanitr's Avatar
Oh by the way I talked to John, and he's gonna sell me the p72,jumperharness,AEM wideband for 350
Old Mar 2, 2008 | 09:04 PM
GS-R Civic's Avatar
Default Re: 10.6.1 comp? (vtec_killer_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_killer_ &raquo;</TD></TR><TR><TD CLASS="quote">
hit me back</TD></TR></TABLE>
Yes I run 93 octane and have a 3 bar map
I was tuned by Jeff Evans both times, he said if I wanted to do a race gas tune we could have easily made 400+ @ ~16psi.
Old Mar 2, 2008 | 10:09 PM
jeff evans ive head alot about him and his tunning abilties on stock motors!! heard of a couple 450whp+ stock GSR's!!
Old Mar 2, 2008 | 11:06 PM
Cole D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringotegra &raquo;</TD></TR><TR><TD CLASS="quote">jeff evans ive head alot about him and his tunning abilties on stock motors!! heard of a couple 450whp+ stock GSR's!!</TD></TR></TABLE>
stock GSR...wow it must have pistons and rods at least
Old Mar 3, 2008 | 05:12 AM
GS-R Civic's Avatar
Default Re: 10.6.1 comp? (Cole D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cole D &raquo;</TD></TR><TR><TD CLASS="quote">
stock GSR...wow it must have pistons and rods at least</TD></TR></TABLE>
http://forums.evans-tuning.com...=4065
450whp 325ft/lbs on a stock motor, only internal upgrade is the ARP head studs.
Its all in the tune
Old Mar 3, 2008 | 06:03 PM
thats joels car!!! [freak] i envy that thing!!
Old Mar 5, 2008 | 09:36 AM
a1320addict's Avatar
Jordan,
You'll be absolutely fine with the stock ITR compression. I would stay under 350whp on pump gas to be safe, anything higher look into running an auxilary race gas map. High compression isn't neccesarily a bad thing for a turbo motor, TonyTheTiger used to run one wicked setup wtih 11.5:1 if my memory serves. The negativite aspect comes in to play on the tuning end of things, as the possibility of bad gas or too much timing will quickly result in detonation, same as with low compression, there's just less headroom.
In regards to my previous setup, it's still runing strong in a friend's hatch N/A, I believe there are some future plans.
It still pulls 220 Compression across the board.
The motor has been through quite a bit: 35,000 stock miles, ~30,000 turbo miles, 200+ passes at the track, never had one issue. Just goes to show tuning is everything
Modified by a1320addict at 2:44 PM 3/5/2008
Old Mar 5, 2008 | 10:26 AM
Default Re: 10.6.1 comp? (a1320addict)
^^^^ listen to him!!!
Old Mar 5, 2008 | 04:57 PM
jordanitr's Avatar
Thank Joel, I was just doing some research to make sure I was ok without tearing into the motor. Can't wait to install it..
