3 bar map sensor installed in stock map sensor, modifying stock sensor
Old Mar 5, 2008 | 03:46 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default 3 bar map sensor installed in stock map sensor, modifying stock sensor
Hi, ive seen on HMT before where a 3 bar map sensor was installed inside of the stock tb mounted map sensor. Anyone have any insight about this or have any advice about doing it? The map sensor i will be using is a Xenocron 3 bar and installing it into a OBD1 B18B stock map sensor. Pic below. Thanks
Old Mar 6, 2008 | 06:47 AM
Default Re: 3 bar map sensor installed in stock map sensor, modifying stock sensor (ForceFed Motorsports)
No one on HT this creative lol
Old Mar 6, 2008 | 07:00 AM
RACEPAK's Avatar
open stock map rivets.
gut it.
place your freescale map in.
solder wires to body.
fill in some epoxy.
close "stock" map.
done
Old Mar 6, 2008 | 07:04 AM
T9U4ReBgO's Avatar
yea I've heard of that am I'm going to do some digging bc I think there is a site that tells u how to do it...
Old Mar 6, 2008 | 07:51 AM
HiProfile's Avatar
Just because its on HMT and not HT, doesn't mean it won't work. And for the record, most people on HT make $200/hr, so its more ecconomical to spend $130 for a prefabbed 4bar than to make an oem-style 2.5/3/4 bar from a stock housing, a $15 sensor, and a half-hour of their time. You pay quite a bit extra just to get a pcb, pigtail, and wires soldered on...
And FYI, its in the engine management subforum on homemadeturbo.com
Old Mar 6, 2008 | 11:01 AM
Default Re: 3 bar map sensor installed in stock map sensor, modifying stock sensor (HiProfile)
Ima try it and hopefully not ruin both my 3 bar and my stock sensor lol. Thanks ill check out the engine management section on HMT. The sensor i got actually fits inside the vacuum source of the stock sensor just need to seal it with something. Its been awhile since id seen it done so was sceptical about doing it but ill give it a try.
I dont make a lot of money but i can spare a half hour lol
Old Mar 6, 2008 | 01:31 PM
nowtype's Avatar
https://honda-tech.com/zerothread?id=2236956
Yes it is a link for my FS but the HMT link is included.
Old Mar 6, 2008 | 01:33 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Just because its on HMT and not HT, doesn't mean it won't work. And for the record, most people on HT make $200/hr, so its more ecconomical to spend $130 for a prefabbed 4bar than to make an oem-style 2.5/3/4 bar from a stock housing, a $15 sensor, and a half-hour of their time. You pay quite a bit extra just to get a pcb, pigtail, and wires soldered on...
And FYI, its in the engine management subforum on homemadeturbo.com</TD></TR></TABLE>
If we made $200/hour, we wouldn't be [freak]ing around with Hondas.
Old Mar 6, 2008 | 01:36 PM
nowtype's Avatar
Default Re: 3 bar map sensor installed in stock map sensor, modifying stock sensor (.dave)
I think he was being sarcastic with the fact most people on Honda-tech are low rent 18-25 year olds with not a lot of money so it would make more sense to rip apart a stock map sensor and solder in a 3-4bar sensor for $40 instead of spending $130 on the Omni/Hondata sensor.
Old Mar 6, 2008 | 01:50 PM
.dave's Avatar
i HAS questions ?
Default Re: 3 bar map sensor installed in stock map sensor, modifying stock sensor (nowtype)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">I think he was being sarcastic with the fact most people on Honda-tech are low rent 18-25 year olds with not a lot of money so it would make more sense to rip apart a stock map sensor and solder in a 3-4bar sensor for $40 instead of spending $130 on the Omni/Hondata sensor.</TD></TR></TABLE>
I know, I just felt like being a ***** about it.
Old Mar 6, 2008 | 03:03 PM
Default Re: (nowtype)
Thats the link i was lookin for, thanks a bunch
Ill ask my buddy to make sure i solder up the correct pins lol
Old Mar 6, 2008 | 05:20 PM
mike93eh2's Avatar
why not just get the omni 4 bar map sensor???
Old Mar 6, 2008 | 05:29 PM
Default Re: (mike93eh2)
Because it costs 125$ compared to the 45$ i spent on my xenocron sensor... im not ht high roller just trying to make a fast car lol.
Old Mar 6, 2008 | 05:53 PM
DfwBB6's Avatar
Default Re: (ForceFed Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">Because it costs 125$ compared to the 45$ i spent on my xenocron sensor... im not ht high roller just trying to make a fast car lol.</TD></TR></TABLE>
wow.....$125 - $45 = $80 difference you prolly spend $80 one weekend on useless stuff why not just save yourself the grief.
Old Mar 6, 2008 | 08:59 PM
Default Re: (DfwBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DfwBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
wow.....$125 - $45 = $80 difference you prolly spend $80 one weekend on useless stuff why not just save yourself the grief.</TD></TR></TABLE>
Obviously dont know me, ima cheap ***. It doesnt even look that hard lol, everyone on honda-tech is willing to dish out money for someone else to do the work for them when you could spend some time and do it yourself
Old Mar 6, 2008 | 10:12 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">why not just get the omni 4 bar map sensor???
It comes with a 2 year warranty & bolts on in less then 2 minutes.
No wiring needed!
Modifying the stock sensor can be done, however we have seen 99% of the people that try this fail to do so. It is not as easy as it sounds.
The difference is DIY versus oem quality plug & play. You make the choice :-)
Old Mar 6, 2008 | 10:16 PM
Default Re: (mtber)
I buckled under the pressure and ordered one a bit ago
Gotta question though, pm'd you.
Old Mar 6, 2008 | 10:24 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">I buckled under the pressure and ordered one a bit ago
Gotta question though, pm'd you.</TD></TR></TABLE>
Replied. Thanks for the order! We still have over 100 units in stock!
Old Mar 7, 2008 | 03:57 AM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">Obviously dont know me, ima cheap ***. It doesnt even look that hard lol, everyone on honda-tech is willing to dish out money for someone else to do the work for them when you could spend some time and do it yourself </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">I buckled under the pressure and ordered one a bit ago Gotta question though, pm'd you.</TD></TR></TABLE>
i see you finally caved or came to your senses...........welcome to the honda-tech way
Old Mar 7, 2008 | 06:45 AM
i see you finally caved or came to your senses...........welcome to the honda-tech way </TD></TR></TABLE>
I caved, found an 80$ in my left sleeve
Ima still try it though lol. Ill put it on my 4 door when i boost it, i want my coupe to look clean though.
Old Mar 7, 2008 | 09:57 AM
boostedDA's Avatar
Only problem now is that your new "sleeper" map now says OMNI across the fcuken top. Should have stayed HMT.
Old Mar 7, 2008 | 10:53 AM
nowtype's Avatar
Jesus Christ. Some of the last words I would use to describe the average Honda-Tech user is sensible.
If you can grab an OEM map sensor for nothing or next to nothing, $50 and 1-2 hours gets you basically the same thing as $120-130 Omni/Hondata sensor. If you can't solder/wire/use epoxy/basic hand tools you wouldn't be able to save that $70. If you can, $70 isn't anything to sneeze at.
Old Mar 7, 2008 | 11:18 AM
Default Re: (boostedDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedDA &raquo;</TD></TR><TR><TD CLASS="quote">Only problem now is that your new "sleeper" map now says OMNI across the fcuken top. Should have stayed HMT.</TD></TR></TABLE>
Yeah i know, oh well. Not trying to hide anything just want something that looks clean and not a gob of jb weld lol. I have appreciation for the HMT guys... if my other map sensor turns out good maybe ill use it instead. Either way both tegs will be turbo and require one so im not at a loss.
Oh and i dont beleive spending unnecessary money is sensible
Old Mar 7, 2008 | 01:31 PM
quicksilver1689's Avatar
i ♥ snails
70 bucks could do alot of fun things
Old Mar 7, 2008 | 02:24 PM
mike93eh2's Avatar
who cares what people spend THEIR money on [freak]...
