Turbo charger help?
Old Mar 6, 2008 | 07:19 AM
PARADOX_sf's Avatar
Default Turbo charger help?
Hi.
I have B16A2 engine an i am going to install turbo charger but i am a little confused.
I am trying to get 350-400whp.
What do you think about this charger:
TURBINE:
Exducer Diameter: 2.63"
Inducer Diameter: 2.91"
Trim: 82
A/R: 0.84
Divided
COMPRESSOR:
Inducer Diameter: 2.38"
Exducer Dimeter: 3.30"
Trim: 49
A/R: 0.70
ANTISURGE
360deg thrust bearing
Old Mar 6, 2008 | 01:29 PM
PARADOX_sf's Avatar
Default Re: Turbo charger help? (PARADOX_sf)
up
Old Mar 7, 2008 | 12:33 AM
PARADOX_sf's Avatar
Nobody?!?
Old Mar 7, 2008 | 08:12 AM
kreat0r's Avatar
i'm really bad with numbers...
got any graphs to go along with these?
Old Mar 7, 2008 | 09:49 AM
PARADOX_sf's Avatar
Default Re: Turbo charger help? (kreat0r)
No turbine or compressor charts
Old Mar 7, 2008 | 06:46 PM
TheShodan's Avatar
Moderator
That's pretty big for a little B16 to get 350-400whp, I sure hope the engine isn't stock or anything. that's a big turbine w/ a big turbine housing. That's gonna lag longer than a a line of tween girls at a Hanna Montana concert
Old Mar 9, 2008 | 01:46 PM
Turbo B18C EJ6's Avatar
Default Re: Turbo charger help? (TheShodan)
I would suggest a t3/t40e 57 trim for your setup. That turbo is great for 300 to 450whp and you will have a TON less lag then the turbo u have listed above. Im using this turbo on my gsr build.
Old Mar 9, 2008 | 05:00 PM
PARADOX_sf's Avatar
Default Re: Turbo charger help? (Turbo B18C EJ6)
How many HP can produce the charger that i described?
Old Mar 10, 2008 | 07:16 PM
hatchkid91's Avatar
i say it will make about 300 -350 depends what mods and what you tune it on
Old Mar 10, 2008 | 08:30 PM
TheShodan's Avatar
Moderator
Default Re: (twinturbosupra123)
with those exhaust wheel measurements, I'd say a bit more than that. But his mission seems to contradict his turbo size.
eglslsd
Jun 14, 2007 05:36 PM
marko_think
Jun 28, 2005 02:55 PM
booscivic
Dec 15, 2003 07:14 PM
SpOonEdOuTeK
Nov 29, 2003 07:52 PM
