ls vtec pistons
Old Feb 28, 2008 | 12:21 PM
LSVtechnologytur...'s Avatar
Default ls vtec pistons
On my last ls/v i used ls crank, block, rods, and pistons(9:1) with a b16 head and that gave me a ~9.7 CR.
I never had the valves hit or anything, but from what i hear its better to use vtec pistons so that you can use larger cams. soooo i decided that i will try them out on a new motor.
That being said, which "vtec' pistons will give me between a 9:1 and 10:1 compression ratio with with ls crank, rods, and a b16 head? (oem head gasket)
thanks
Old Feb 28, 2008 | 04:01 PM
jfoster's Avatar
Default Re: ls vtec pistons (LSVtechnologytur...)
Not sure , have you played with a calc ?
http://www.c-speedracing.com/howto.php
Old Feb 28, 2008 | 07:50 PM
inspyral's Avatar
Why not use a forged piston(and rod for that matter)? Most forged pistons have oversized reliefs, and a lot use the same par tnumbers for VTEC and non-VTEC applications, so the only difference is the actually CR you end up with when using different heads. A typical flat top forged piston should yield the CR you're looking for, while also having larger valve reliefs.
Old Feb 28, 2008 | 11:37 PM
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Why not use a forged piston(and rod for that matter)? Most forged pistons have oversized reliefs, and a lot use the same par tnumbers for VTEC and non-VTEC applications, so the only difference is the actually CR you end up with when using different heads. A typical flat top forged piston should yield the CR you're looking for, while also having larger valve reliefs.</TD></TR></TABLE>
I forgot to mention, i'm looking for forged after market pistons. I was under the impression that the non vtec pistons (even in the aftermarket world) did not have adiquite valve reliefs. however, i recently heard from a friend that alot of the pistons are cut the same.
so i should be alright w/ whatever i order as long as the compression is right? I'll double check w/ the company i order from, but thanks for the info guys
Boostage
Jan 16, 2009 07:59 PM
Way2JDMdc5
May 7, 2008 12:51 AM
HondaBurger
Sep 19, 2007 02:36 PM
Ak_ef9
Dec 11, 2006 12:41 AM
chuckd05
Mar 26, 2003 08:15 AM
