Spark plug gap and Injectors
Old Mar 8, 2008 | 10:08 AM
DOHCIVIC's Avatar
Default Spark plug gap and Injectors
I am looking for answers on what gap to set my denso Ir. plugs and what injectors should I be running with my setup.
I have a B16a2 with a greddy turbo kit... The kit came with 310 injectors... What are stock injectors and are my injectors (now) big enough.
Old Mar 8, 2008 | 11:35 AM
Silva Bullit DC4's Avatar
Default Re: Spark plug gap and Injectors (DOHCIVIC)
Did your Greddy kit come with any engine management? And if not, what is your hp goal?
Old Mar 8, 2008 | 11:37 AM
patrick4588's Avatar
set the gap to .28 and those 310cc are kinda small. if you plan to run more than 6psi or so, you need to upgrade.
Modified by patrick4588 at 2:54 PM 3/9/2008
Old Mar 8, 2008 | 07:42 PM
Schister66's Avatar
Man U FTW
For plugs i would use NGK BKR7e's at a .28-.32 gap. The injectors are a little small, but using the ~6cc/whp you can figure out approximately what they're good for.
310cc x 4cyl = 1240cc total
1240cc / 6cc(per whp) = 207whp with a safe injector duty cycle approximately in the 75-85% range.
Old Mar 9, 2008 | 09:28 AM
DOHCIVIC's Avatar
I'm looking for 300+ whp... So if iI get the RC 750 cc, they are over kill but they would be good up to 500whp
as for the spark plugs... I have already bought Denso IK22 and IK24 plugs... I put the 22's in yesterday and they made a work of diff... I set the gap .27-.30
Old Mar 9, 2008 | 09:49 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCIVIC &raquo;</TD></TR><TR><TD CLASS="quote">I have a B16a2 with a greddy turbo kit</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCIVIC &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking for 300+ whp</TD></TR></TABLE>
A greddy kit is not ideal for 300+ whp.... that's one of the reasons it only came with 310's.
You have some searching to do.
"Your search for greddy dyno returned 49 results."
Old Mar 9, 2008 | 10:26 AM
Schister66's Avatar
Man U FTW
You're going to be pushing that Greddy kit to hit 300whp. If you want that much power, i suggest a new setup. With the Greddy, you'll be good around 240-250whp. Another thing to consider is the fact that the Emanage wont work with a larger injector; therefore, you'll have to ditch that and move up to something like Crome/Hondata/AEM, etc...
As for the injectors, a set of 440 or 550cc should work fine. The 440s are good to about 300whp and the 550s to about 380.
Old Mar 9, 2008 | 10:34 AM
DOHCIVIC's Avatar
I'm sure i'm like everyone else... I'm not made of money so I am stuck with the greddy kit... I am switching to OBD1 and tuning on that till I can afford something else... also ditching the emanage
As for the injectors... I was thinking the 750cc were a bit much so I'll look for a good price on
some 550's
Old Mar 9, 2008 | 11:05 AM
hondamn1320's Avatar
Default Re: (DOHCIVIC)
you can find some cheap DSM 450's for less than $100.
Old Mar 10, 2008 | 02:49 PM
DOHCIVIC's Avatar
Default Re: (hondamn1320)
Kinda scared of used injectors
Old Mar 10, 2008 | 05:34 PM
then get them cleaned and balanced
STEN_714
Dec 20, 2014 03:30 AM
949
12
May 12, 2008 07:30 AM
slowasscar
Jul 27, 2006 06:08 PM
Layziebtnh055
Apr 18, 2004 10:20 AM
