hondata/omni 4bar sensor work with s100?
1 Post
I been looking into getting the hondata or omni 4 bar sensor for first turbo build. I like the plug and play feature and simplicity of them. Can i use one of these map sensors with the s100?
1 Post
Re: hondata/omni 4bar sensor work with s100? (KENetics1)
so just tell the tuner the setup obvisiously and that im using a one of those map sensors and they will take care of the rest ?
Re: hondata/omni 4bar sensor work with s100? (dc4teg95)
wow going big on the first build needing to measure up to ~45psiG.
Map sensors are not something you want to oversize on, you loose too much resolution.
1 Post
Re: hondata/omni 4bar sensor work with s100? (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">wow going big on the first build needing to measure up to ~45psiG.
what would be a good map sensor to go with? im learning as i go with this
While this is true on paper, you loose resolution, the computer works in voltage and it interprets the signal perfectly and runs great. You can't tell the difference on a stock car between the stock map sensor and the omni.
The 4 bar will work with the S100 if your tuner has the Rom Editor 4 software.
Re: hondata/omni 4bar sensor work with s100? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
The 4 bar will work with the S100 if your tuner has the Rom Editor 4 software. </TD></TR></TABLE>
Still haven't used mine yet tony...lol I bought one off of Tony to try and compare it to the old GM sensor I had. I'll keep everyone posted.
Re: hondata/omni 4bar sensor work with s100? (ladysman)
i used one the other day on a prelude that was only running 7psi with s100
everything worked exactly the same as a 3 bar or even a stock map sensor
