Oil Catch Can?
Does the oil catch can have to have a breather on top or can the can it's self be closed off with just the oil inlet lines? The one I'm looking at has the return oil line back to the block but I've heard it can contaminate the oil, so I might not be using the return. My questions is more related to the catch can it's self. I'll be coming off the block and eliminate the existing PVC system, so I want to know if the closed catch can will work for a 300HP DD or the breather on the can is a must? Thanks guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evilparadize »</TD></TR><TR><TD CLASS="quote">Does the oil catch can have to have a breather on top or can the can it's self be closed off with just the oil inlet lines? The one I'm looking at has the return oil line back to the block but I've heard it can contaminate the oil, so I might not be using the return. My questions is more related to the catch can it's self. I'll be coming off the block and eliminate the existing PVC system, so I want to know if the closed catch can will work for a 300HP DD or the breather on the can is a must? Thanks guys!</TD></TR></TABLE>
the oil isnt only the issue. there is also crank case pressure. it has to go somewhere. it either has to be evacuated, wither via a vac pump, or allowed to vent. i think a vac pump is out of the question for you, so the alternative is the breather.
Is it possible to run just one line from the back of the block to the catch can and leave the other port on the can open to serve as a breather? Can I'm looking at has 2 inlet ports for the oil but no breather. I know the more air that vents out is better but I wanted to know if this would work, thanks.
Touge Tuning
May 2, 2008 05:27 AM
Touge Tuning
Feb 9, 2007 11:24 AM
97grnrs
Nov 21, 2006 10:35 AM
