sleeving a block? yes, but what's the best bore size 4 turbo???
hey i just decided to sleeve my gsr block but i'm just wondering whats the best bore size for turbo???
i did a search all over but i can't find a good answer
jgdinamics says 82mm is good for 50psi-max and 84mm good for 45psi-max.
about my power goals (get the most HP out of a t3/t61 probably around 22psi)
ohh golden eagle sleeve's ...
LMK thanks
LMK thanks
Re: sleeving a block? yes, but what's the best bore size 4 turbo??? (ONE*SICK*FERIO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONE*SICK*FERIO »</TD></TR><TR><TD CLASS="quote">hey i just decided to sleeve my gsr block but i'm just wondering whats the best bore size for turbo???
LMK thanks</TD></TR></TABLE>
ehh i would not trust a word JG says but for what your shooting for i think 83-84mm should be fine.
Re: sleeving a block? yes, but what's the best bore size 4 turbo??? (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote">83-84 </TD></TR></TABLE>
sounds about right
sounds about right
Re: sleeving a block? yes, but what's the best bore size 4 turbo??? (94GSRCivic)
I remember asking the late Earl (rip) the same question a few years back and he recommended 83mm just in case I had a mishap and I needed to rebuild so I could still go to 84mm. If you start at at 84mm and something goes wrong, although you technically can go bigger Earl didn't think it was a good idea with a lot of boost (due to thin walls between the cylinders on the 85+mm builds).
good luck
good luck
Re: sleeving a block? yes, but what's the best bore size 4 turbo??? (markaria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94GSRCivic »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markaria »</TD></TR><TR><TD CLASS="quote">
THANK YOU ALL
83MM WON
THANK YOU ALL
83MM WON
calib17a
03-18-2004 01:17 AM
