What model ATI dampers for 500+ whp
Old 03-08-2008, 09:26 AM
Max500's Avatar
Default What model ATI dampers for 500+ whp
Ok so I need a damper and was looking at the ATI damper over the Fluidampr but I noticed that the ATI dampers are available in "race only" versions for over 500 hp. The race only version only drives the alternator and come in 7.074" OD and a 6.325" OD. The race only version also come in different weights for a total of 4 different race only models. I am confused as to which one would be better for me. All insights are much appreciated.
Old 03-08-2008, 09:32 AM
BCICAN
Dunc's Avatar
Default Re: What model ATI dampers for 500+ whp (Max500)
Why not just use stock?
Old 03-08-2008, 09:53 AM
WalkerGSR1's Avatar
Stock pulleys don't absorb the vibrations of built motors.
Old 03-08-2008, 10:06 AM
ctr83's Avatar
is your car a full time race car or do you run it on the street too?
Old 03-08-2008, 10:29 AM
Max500's Avatar
im planning to make over 500 whp and I run it on street and strip. Anyone know about these different models of ATI dampers?
Old 03-08-2008, 10:30 AM
Suprdave's Avatar
Default Re: (WalkerGSR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">Stock pulleys don't absorb the vibrations of built motors.</TD></TR></TABLE>
Hahahahahahaah...I seriously love this place.
Old 03-08-2008, 11:08 AM
BCICAN
Dunc's Avatar
That's interesting, I guess my car (any many other people with 5-600hp on the street) is on the verge of breaking down since it's built and has been that way for 5 years now of daily driving? How does changing out pieces of metal in the motor, stock, for another hunk of metal, "built," change anything in the vibrations?
Old 03-08-2008, 12:00 PM
purpleh22's Avatar
Default Re: (Dunc)
Well, if you have a high hp H22 - - try using an aluminum pulley and find out. Some of the aftermarket pullys do a BETTER job of dampening harmonics. Like aftermarket rods - better in some severe service applications.
See lab tests - -
Old 03-08-2008, 02:31 PM
turbotypeR@SPEC's Avatar
Default Re: (purpleh22)
i use the street damper in my car
Old 03-08-2008, 03:40 PM
ej8
ej8's Avatar
Default Re: (turbotypeR@SPEC)
If they didn't do anything they wouldn't be a safety requirement...
They work well and your bearings and oilpump, mainly, will thank you for it, especially for high-rev setups.
Old 03-08-2008, 04:01 PM
Semnos's Avatar
I wonder what every racer used before ATI or Fluidampr made pulley's for honda's.
Old 03-08-2008, 04:14 PM
markaria's Avatar
Default Re: (Semnos)
I have close to 40k miles on my built motor with a fluidamper (thanks arturbo) and no problems with my oil pump... cant tell ya what the stock pulley would have done but I know a few hundred dollars of piece of mind is worth it when spending thousands to me.
Sorry I dont have any experience with ati.
Old 03-08-2008, 04:35 PM
STEEZY_EG+DC's Avatar
Default Re: (markaria)
the race version is when your only gonna use the alternator pulley. the street version is when you use the ac and powersteering along with the alternator pulley
Old 03-08-2008, 05:04 PM
blinx9900's Avatar
Default Re: (STEEZY_EG+DC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEEZY_EG+DC &raquo;</TD></TR><TR><TD CLASS="quote">the race version is when your only gonna use the alternator pulley. the street version is when you use the ac and powersteering along with the alternator pulley</TD></TR></TABLE>
so if you dont have AC or PS should you just get the race version or are the other differences?
Old 03-08-2008, 06:08 PM
Max500's Avatar
To my understanding, there are a couple different race version models as well.
Old 03-09-2008, 04:53 AM
ej8
ej8's Avatar
Default Re: (Max500)
The race version underdrives the alternator too, also requiring a shorter belt
Old 03-09-2008, 10:16 AM
full Circling's Avatar
Location: That's the wrong tone... I'm Skunk2 certified.
Just call ATI. They would be able to help you better than we would.
Old 03-09-2008, 10:54 AM
ctr83's Avatar
Default Re: (full Circling)
call mike, at lasky racing he will be able to help you out.
Old 03-05-2009, 11:50 AM
eight equals equals equals D
Tim2179's Avatar
OP, how much HP are you making?
The "street" version will handle 500 Hp or more. It has a removable P/S drive.
The race version is "race only" b/c of the Alternator drive on the damper hub is ~30% underdriven - ie, you wont have enough juice to run all your accessories like HEADLIGHTS (yikes) so you shouldn't get this one unless you truly are just racing - or you don't like to listen to the radio and drive at night.
The 6.3" "race" damper is only good for up to 300 HP since it has a lighter aluminum inertia ring (that's the weight inside the damper)
The 7" race dampers are designed for +300HP and beyond.
Call Ricky at ATI (877-298-5040 or 410-298-4343) and he'll be able to tell you exactly which damper you need depending on what type of driving or racing you do.
Old 03-05-2009, 11:56 AM
kte324's Avatar
Im trying to make 650whp and I was looking at the race version from fluidampr, but the car is going to be street driven. So will I be able to listen to the radio, use my headlights and power the electronics in my car since it is underdriven??? Thanks.
Old 03-05-2009, 12:18 PM
Tim2179's Avatar
If you go with the Fluidampr you'll have to cut your timing cover apart...you'll have to ask someone w/experience with the Fluidampr to fully answer your question though.
ATI developed the race damper a few years prior to their street version, and it is designed for racing - not running your accessories. They have NO drive for PS or AC.
The 'street' versions are still capable of being used in race applications, but have all the accessory drives. However, it's not really meant to be used on anything with much more than 500 HP - but it would be better than the OEM unit.
The street version came about when ATI saw there was a market for high hp street driven import cars and began manufacturing stock size (~5.5" od dampers) a few years after they developed the race version.
Old 03-05-2009, 05:35 PM
kte324's Avatar
I've heard about cutting the timing cover. I dont have ac or ps so im not worried about the extra pulleys. I guess im leaning more to ATI since I hear its more rev liking and I dont have to modify anything.
turboedc2
04-19-2006 07:06 AM
Tyson
17
12-07-2004 03:52 PM
scca54ita
04-16-2004 04:26 AM
Civic44
26
08-13-2003 12:32 PM
EF8VTEC
05-29-2003 11:18 AM
Quick Reply: What model ATI dampers for 500+ whp
