ls Vtec turbo?
I am putting a turbo in my LS Vtec but I am having trouble finding were to connect the oil feed line for the turbo. I already have an oil line coming off of the oil pressure sending unit by the oil filter. Should I run a T fitting off of that line or is there another spot that I could go with. I am also looking for waste gate, I dont know much about them but I herd that certain waste gates let you boost lower than a normal one would. If any one knows what I'm talking, could you help me out?
I always put a T on the oil pressure unit on the back of the block ran one to the turbo and the other to the autometer gauge. I dont think you should run it off the sandwich plate for the ls-vtec your head needs all the oil it can get
...about the wastegate there are different spring's inside them to control your boost unless you running a boost controller...
you should probley research more before you turbo if your asking questions like this
...about the wastegate there are different spring's inside them to control your boost unless you running a boost controller...you should probley research more before you turbo if your asking questions like this
I think that it would hurt your oil pressure to your head by having some T's in it, I would also want to know how to do this because I will be in the same position you are in. Is it a bad idea to run an electronic oil pressure gauge? Bump
Griffin@Camtech
Feb 24, 2004 05:58 PM
crx1856
Nov 2, 2003 11:50 PM
