water injection+JRSC = lower IATs?
I was wondering if anyone had any insight on JRSC setups with water injection. I was wondering if when using water injection there is an "actual" reduction in IAT seen by the IAT sensor? If so, how much? where do you have the injection tapped?
Re: water injection+JRSC = lower IATs? (wfocrx)
Yes, you will produce lower intake temps.
You typically mount the nozzle in the intake pipe.
The greatest benefit will rise from your greater knock threshold however.
Re: water injection+JRSC = lower IATs? (MooreBoost)
A Water/Meth 50/50 mix will net you large gains on a SuperCharger. Your intake temps will drop drastically...straight meth would be even better (if you're safe about it).
98civicguy
04-26-2004 07:34 AM
