J&S Questions
Yes I've searched. I bought my car with this unit installed.
Sorry for the phone pics:
I know it's not Version 2 because it doesn't support map. It is an older unit, has a RECTANGULAR, not 2 1/16 dual monitor for knock and A/F. What version is this?
Someone was talking about the dip switch settings but mentioned up to 6 switches, obviously this has 4.
Importantly, using the stock knock sensor, the system reads knock when I hit vtec and severely retards the timing even though its just normal noise. I do have the supplied knock sensor that isn't used. People say stick with the stock sensor. Is it any less/more sensitive than stock, and where the hell do you mount this sensor? I read you're supposed to wire an "aux" of this unit to the vtec wire to ignore vtec noise, but clearly mine doesn't have that.
any advice?
any advice?
call Jhon at J&S somewhat hard to get ahold of, but he LOVES to talk about his products he'll be able to tell you all about it, i know the version 2 has a spot to hook up a signal wire so the unit knows when vtak engages.... (i have the version 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20luda »</TD></TR><TR><TD CLASS="quote">call Jhon at J&S somewhat hard to get ahold of, but he LOVES to talk about his products he'll be able to tell you all about it, i know the version 2 has a spot to hook up a signal wire so the unit knows when vtak engages.... (i have the version 2)</TD></TR></TABLE>
Got his number on hand? Sorry if i'm too ignorant to look myself, people on this board like to snap sometimes
That unit was probably made in '98. Switches 3 and 4 both up for Honda.
TPS input is used to disable knock detection when TPS voltage is less than 1.5v.
Newer units had a VTEC input pin, to temporarily desensitize during VTEC engagement.
I could reprogram the TPS pin to do that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EASY101 »</TD></TR><TR><TD CLASS="quote">just out of curiosity is "ultraspeed" meant as in "team ultraspeed"?
Yes it is, why?
And thanks John, what do the first 2 dip switches do? Should I leave the first one up as I saw from your archived instructions?
Yes it is, why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John at J&S »</TD></TR><TR><TD CLASS="quote">
Dizzam, I wish I knew that before I sold mine long ago.
