Axles Axles Axles, What do you use?
Like the title states, what axles are you running and what kind of power numbers are you putting down, anyone can chime in.
Re: Axles Axles Axles, What do you use? (youdontneed2cams)
450whp, I have been running Gator Racing Axles for 2.5 years now. Just recently tore my inner boots, called them up and they said ship them back we will fix and bill you only for what needs to be replaced.
Re: Axles Axles Axles, What do you use? (cjordan)
DSS level 5.9s
Broke everything else under the sun, car is sitting at the upper 600's makes the occasional push above that
Re: (.adam.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .adam. »</TD></TR><TR><TD CLASS="quote">stock w/ 415whp
soon to be stock w/ 600+whp haha</TD></TR></TABLE>same here
Re: (turboedc2)
autozone lifetime replacement.
went a whole season making mid 300s on the same set
went the next year making low 400s on a different set. havent broke one yet
i ♥ my honda
Global Mod
Global Mod
Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">gator stage 3 mods at 520 whp, broke one, the fixed it with the wrong joint, broke that, gave up.
d.s.s. level 5.9's now 710whp.</TD></TR></TABLE>
Hoping those 3mods work out for me. lol
Re: (Cm0ney)
ive broken two gator axles, the "carbon fibre" ones. One broke where it connected into the wheel on the driver side, had it replaced (they gave me a hard time about it) then broke the passenger side inner joint, and i just replaced it with an autozone axle didnt bother with them anymore. I had 270whp....
so now im running one gator axle and one autozone axle, i will be damned if the gator axle breaks before the autozone one.
Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">autozone lifetime replacement.
went the next year making low 400s on a different set. havent broke one yet</TD></TR></TABLE>
same here
same here
Re: (cluelessmale)
On most B series with your car lowered a little bit, do your axles angle up going to the hubs? I would see this as breakage waiting to happen. I would think that the straighter the better? am I thinking right? how do you guys deal with this? I think that is a factor in why some people have expensive/cheap/remake axles break on them all the time.
Re: (youdontneed2cams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youdontneed2cams »</TD></TR><TR><TD CLASS="quote">good stuff guys, any lower power setups? any ideas of what kind of power stock axles will take?</TD></TR></TABLE>
i went 9.8 @ 158 on stock axles.
