F.Y.I. 88-91 OEM CRX Labels part numbers
Old 02-08-2012, 03:47 PM
Rob.'s Avatar
Icon6 F.Y.I. 88-91 OEM CRX Labels part numbers
If you are looking to restore your CRX back to OEM, there is nothing nicer than having
the correct labels on your parts to give it that 100% OEM factory look.
Here's some info I dug up, that dont sometimes show on dealer parts lookups.
Spare Tire plate Caution:
Part Number: 42767-SA5-670
Underhood Information Service & Emissions Label
w / o Calif Injection System
DX Model
1988 17277-PM5-A01
1989-91 17277-PM5-A02
HF Model
1988 17277-PM8-A00
1989-91 17277-PM8-A01
Si Model
1988 17277-PM6-A00
1989-91 17277-PM6-A01
w / Calif Injection System
DX Model
1988 17277-PM5-L01
1989-91 17277-PM9-L11
HF Model
1988 17277-PM8-L00
1989-91 17277-PM8-L01
Si Model
1988 17277-PM6-L00
1989-91 17277-PM6-L01
Fan Caution Label (Located On radiator)
w / Toyo Radiator
1988 19018-657-000
1989-91 19018-P08-000
w / Denso Radiator
19018-PK1-003
Upper Timing Cover Label (Located ontop of upper timing cover)
31117-PM5-A00
Tire Pressure Label (Located on left side inside Glove box)
DX Model
1988-89 42760-SH3-T30
1990-91 42762-SH3-A50
HF Model
1988-89 42760-SH3-T10
1990-91 42762-SH3-A40
Si Model
1988-89 42760-SH3-T50
1990-91 42762-SH3-A61
Fuel Filler door label (Unleaded Fuel Only) (Located inside Fuel door)
17669-SA0-670
Intake Manifold decal (PGM-FI)
(MULTI PORT/PGM-FI) 17113-PG7-310
(DUAL POINT/PGM-FI) 16489-PM5-A00
Fuse Label under dash
77762-SD4-000
Ignition Switch "Push" Label (Located on steering column cover)
53231-SB2-000
Reserve coolant tank Label (Placed ontop of coolant tank cap)
19105-PM3-000
Airbox intake info Label (Located ontop of airbox)
1988-89 17273-PE7-661
1990-91 17273-PM5-A00
Fuse Box Label (Located ontop of engine bay fusebox - comes with fuse box lid only)
38250-SH3-961
Rear model decal
75723-SH2-A21ZB - Si (red)
75723-SH2-A00ZE - HF (light grey)
Rear Grey 'HONDA' decal
75712-SH2-000ZJ
Front Hood chrome 'H' Emblem
75700-SG0-000
1991 Special edition door decal
75772-SH2-C91ZA
'CRX' Rear Garnish Decal
08999-DEC-540
update: Clear round stickers where the black grommets contact the door/hood/hatch of the body
Part Number: 85268-SA0-000
Before:
After:
Old 02-08-2012, 04:19 PM
PHANTOM MENACE
24TEN's Avatar
Default Re: F.Y.I. 88-91 OEM CRX Labels part numbers
Awesome!!
Old 02-08-2012, 07:21 PM
zrickety's Avatar
Hey Rob, how about a B16 VT or SiR underhood label? That's what my car really needs.
Old 02-08-2012, 08:36 PM
dacrxguy's Avatar
what about the pgmfi sticker on the intake manifold and a/c stickers.
Old 02-09-2012, 04:01 AM
TearSDMF89dx's Avatar
how about a sticky for this thread .... good info
Old 02-09-2012, 06:08 AM
Rob.'s Avatar
I didnt get into UKDM, EDM, or JDM part numbers.. Just North America.
Old 02-09-2012, 10:01 AM
Rob.'s Avatar
Updated
Old 02-09-2012, 11:09 AM
my91tealhb's Avatar
Rob,
This is great thanks! Too bad many are discontinued!
Old 02-09-2012, 09:22 PM
hoga113's Avatar
How bout 94 del sol vtec ? that gonna really help to get the b16 bar'd
Old 02-10-2012, 06:22 AM
Rob.'s Avatar
Please dont mention del sol in my thread...
Old 02-10-2012, 07:08 AM
mt-fly-boy-25's Avatar
swweeeeeeeeeeeeeeet!
Old 02-10-2012, 04:11 PM
Rob.'s Avatar
updated
Old 02-10-2012, 07:36 PM
hoga113's Avatar
Sorry
Old 03-05-2012, 05:34 PM
Rob.'s Avatar
Sorry
lol
Old 03-07-2012, 08:03 AM
pholife's Avatar
thanks Rob! Which ones are discontinued?
Again, ty.
Old 03-07-2012, 08:55 AM
hondahondasi's Avatar
Thanks, I will be using this Info!
Old 03-07-2012, 01:55 PM
my91tealhb's Avatar
I was able to get the Ignition Push Sticker and the one that goes on the cam cover. I really want the coolant tank label but discontinued!
Thanks Mr. Rob
Old 03-12-2012, 02:20 PM
Jaime 91SiB18's Avatar
Always good pics, good tech, or both out of Robb!
Old 06-30-2012, 05:42 PM
Rob.'s Avatar
No problem.
Old 07-03-2012, 01:11 PM
my91tealhb's Avatar
Emission Label for California is discontinued! Went to dealer last week!
Old 07-04-2012, 07:54 AM
STEADY's Avatar
I odered four decals on 7/03 from Sons Honda (local so I can pick up). I'm waiting on refunds for the ones not available. I'll update this once I see which ones are not available.
1 EMBLEM, IN. MANIFOLD (PGM-FI) 17113-PG7-310 $9.90
1 LABEL, FAN CAUTION 19018-657-000 $2.77
1 PLATE, CAUTION 31117-PM5-A00 $4.02
1 EMBLEM, REAR (RED) (SI) 75723-SH2-A21ZB $8.03
I'm pretty sure the rear emblem is discontinued but I can get one off ebay.
I really like the Special Edition door decal but couldn't get it to pull up online. Anyone know how I can try and order one?
Thanks!
Old 07-04-2012, 08:25 AM
Rob.'s Avatar
Thanks!
Here: http://www.canadianhondaparts.com/OrderParts.aspx
Look at 1991 CRX Si.
http://www.canadianhondaparts.com/Pa...per&illid=9532
Old 07-04-2012, 08:51 AM
STEADY's Avatar
I just figured out that these decals will run in opposite directions on the car - I assumed there would be a left and right.
Not sure I want to try and order them or not. Thanks for the link!!
Old 07-05-2012, 11:16 AM
STEADY's Avatar
Thanks!
All of these have been discontinued...
I've seen the rear red Si emblem on ebay but none of the others.
Old 07-06-2012, 01:37 PM
#1 Super Guy
94eg!'s Avatar
Here is another one to add to the list for those of you with CRX's that were actually made in Japan. BTW: I didn't host this picture myself, so you may want to copy & re-host it so it doesn't disappear in a year or two.
Made in Japan = 87125-041-680
Still looking for the part number for this one found on the Candian Civics & CRXs. Anybody know?
Made in Canada = ??? (might be 87125-S10-A00)
***edit: HFC134a sticker is 80050-SP0-000
I "think" (not positive) these are the codes for the Del Sol VTEC emissions labels. Not sure which one is which year though, so you will need to contact your parts dealer to be certain. I would think 1994 would be A00 and go up from there. You will need at least a correct vin number to order the emissions label, so be aware.
17277-P30-A00
17277-P30-A01
17277-P30-A02
17277-P30-A03
Quick Reply: F.Y.I. 88-91 OEM CRX Labels part numbers
