suspension help needed!!
1991 civic hatch si. the car has had a terrible lean on the back driverside since i got the vehicle. ive swapped shocks and spring to try and fix it, but nothing. its still the same. any help? top is rear pass and bottom is rear driverside.
Re: suspension help needed!!
Yeah. I've also been all up under it with a tape measure trying to figure out why it's doing it. I'm thinkin it a bishing and I just can't actually see it.
The springs and shocks are fine I can't visibly see any worn out bushings or anything bent and I dot believe the chassis is bent. Someone told me to check if there is a bushing between the shock and the body. I haven't had the time to crawl under it. I'll be checking today.
are the bushings for the trailing arms and lower control arms press in press out? like with a shop press? bc ill change all the bushings and go from there.
wuggiewuggie
Suspension & Brakes
02-22-2007 11:50 AM
