oBD0 code 11
oBD0 code 11
My ecu is throwing code 11, and from all my research, no one seems to have a description for it... Does anyone know what code 11 is. One guy suggested it was an ABS sensor, but hes the guy i bought it off, so for all i know, he could be giving me a line of BS lol. I trust the guy, but if someone could verify, that would be awesome.
Thanks!
Thanks!
$cat /dev/urandom
Re: oBD0 code 11
There is a code 11.. it is for cars that were sold without a catalytic converter.. Code 11 is for a sensor called the IMA sensor.
The IMA sensor manages how much CO is in the exhaust using the O2 sensor as a guage.
Since you didn't mention what ECU you are running, its a guess, but my money is on that you have an ECU looking for an IMA sensor, and a car that doesn't have one.
Your options are to get a different ECU that does not expect an IMA sensor, or do the work to install the IMA sensor the ECU is looking for.
Re: oBD0 code 11
Im using a mp7. Sorry about that, thought i mentioned.
Pm7s on a 91 ef with a dohc zc. Does this sound right?? My car has a cat converter btw, but i guess jdm efs with a zc didnt have one?
$cat /dev/urandom
Re: oBD0 code 11
Your problem is exactly the one I describe then.. The PM7 is one of the ECU's that has this problem. Your choices are to wire up the IMA sensor, which i would say is a waste of time and energy, find a new PM7 that is not one that looks for the IMA, or find a chipped PM6 and run PM7 maps in it.
Out of those 3 options, the chipped PM6 might be the easiest.. talk to chris or any of the people at xenocron.com and he can get you the ECU you need.
Re: oBD0 code 11
You posted on my other thread. Im thinking i have a jammed wide injector... Thoughts??
Re: oBD0 code 11
if you think its your injectors take them out inspect, and test with a multimeter.
$cat /dev/urandom
Re: oBD0 code 11
Doing one of the things I mentioned will absolutely have a huge impact on your e-test. Right now, that ECU is looking for a sensor that is used to control your car's emissions, and not finding it at all.
I bet even getting a PM6 that isn't chipped would be a substantial improvement to what you have now.
Re: oBD0 code 11
But my main concern in doing a bunch of work the wont solve the problem. Im not being lazy lol, I just an a busy dude! These are some figures im getting...
Curb Idle
HC ppm - limit = 200 reading = 1278
CO % - limit = 1 reading = 6.89
NO ppm - limit = 864 reading = 2470
So going with those numbers, what do you think, will the ecu fittling do it justice and pull those numbers down? or do i have something hideously whole with my engine? lol
Re: oBD0 code 11
this is UK PM7 with the IMA sensor:
Re: oBD0 code 11
Hey jilicrx, thats super helpful, thanks! Ive spent so friggin long looking for PM7's, and the one I find doesnt work :/ Its just frustrating that i cant get a damn ecu that works! I ran a PM6 before and the emissions were about the same. There has got to be something wrong with the engine, asides from the ecu. If a PM6 didnt fix it, or at least bring it down, I doubt its ecu related. Is that too bold a claim??
