crx gsr wiring help
Old 07-22-2014, 05:42 PM
thatdumbass's Avatar
Default gsr swap info
so i bought a 2001 gsr swap other day. which im going to convert to OBD1. my current swap is a z6/b7 with a rywire mpfi obd0-obd1 jumper.
my question is when i attempt the swap do i need to find a gsr wiring harness? or do i use my original obd0 harness?
this is the first swap ive done fully myself so im little confused
Old 07-24-2014, 03:42 PM
Default Re: crx gsr wiring help
bump
Old 07-24-2014, 04:01 PM
Keyboard Humorist
4drEF's Avatar
You will simply be taking your engine haress off the D16Z6 and using it on the GSR motor.
Most jumper harnesses include all the wires necessary to convert to use any OBD1 motor.
I would assume the RWire jumper you have them as well so you can hook up to the extra sensors found on the GSR -IAB and knock sensor.
Old 07-24-2014, 04:04 PM
Originally Posted by 4drEF
You use your OBD0 engine harness and convert as necessary to plug into all the sensors.
The OBD1 jumper harness will have wires for the IAB, vtec, heated O2 sensor, knock sensor, and whatever else your GSR engine requires.
What engine is currently in your car?
z6/b7 mini me.
Old 07-24-2014, 04:13 PM
Keyboard Humorist
4drEF's Avatar
Sorry - I edited my post while you were replying.
Old 07-25-2014, 07:19 AM
CRX God
whited's Avatar
You need a jumper for your ECU, you potentially need a vtec sub harness. The OBD0 to OBD1 jumper for the distributor is also very helpful as well. If you have the old wiring harness you can swap out the other plugs. The alternator I wired myself.
Use the injectors off the D16 and then you don't have to worry about the resistor pack.
Old 07-25-2014, 07:21 AM
Keyboard Humorist
4drEF's Avatar
^^ he has the OBD1 RyWire jumper already since he has a D16Z6 swap.
Old 07-25-2014, 08:22 AM
Freemananana's Avatar
I'm pretty sure everything will be plug and play as long as you have the right motor mounts. Should drop in just as easy as the D-series comes out.
Old 07-25-2014, 12:08 PM
Technical Hero
HondaPartsHero's Avatar
What ecu are you using? Unless you use the P72 ECU you won't need the IAB wiring. What ecu are you using?
Old 07-28-2014, 01:08 PM
i think im goin to run a chipped p28. but a buddy of mine has a p72 so i might use it idk yet.
Old 07-28-2014, 01:50 PM
Keyboard Humorist
4drEF's Avatar
If you run an intake manifold without IAB then you should be fine with the P28. Tuning would be best, but will drive your cost up over the price of a P72 unless you can tune.
The P28 can also be modified to support IAB control so you can then run the P72 map and you would never know the difference.
http://www.xenocron.com/xenocron-iabs-parts-p-131.html
http://www.xenocron.com/install/OBD1-IABs.htm
I have personally added this of kit to a P28 ECU for OBD2 IAB control and it worked fine.
kennybintegra
13
11-24-2019 09:22 PM
DA STRIKER
03-02-2011 08:48 PM
MI4$DC5
11-25-2005 04:25 PM
Quick Reply: crx gsr wiring help
