eBay Turbo Garbage?
eBay Turbo Garbage?
So, I just checked my turbo for shaft play for kicks and its wiiggling; the damned thing is relatively loose and has been rubbing against the inside wall of the inlet as it spun. Oil was always provided to the turbo with a restrictor as well, so lack of lubrication couldn't of caused this. Anyone have similar experiences?
Just great, thank god I'm not too upset considering they sell for $200.00
I need some good recommendations for a new turbo, something of decent quality; a Garrett or something with an internal wastegate perhaps. But also won't break the bank.
Re: eBay Turbo Garbage?
http://www.ebay.com/itm/88-00-Civic-EF-EG-EK-1-5L-1-6L-D15-D16-D16Y-SOHC-T3-T3-T4-T04E-Turbo-Charger-Kit-/171388486327?pt=Motors_Car_Truck_Parts_Accessories&hash=item27e78cc2b7&vxp=mtr
This is basically what I have, the exhaust manifold is the exact same one.
What turbo manifold do you have?
What motor? D16A6 Block, D1yY8 Head MiniMe
Modifications? Eagle Rods, Vitara 75mm Pistons, 320CC Bosche OBD1 Injectors, P28 Chipped ECU, Adjustable FPR, Wahlbro 255LH Pump
Exhaust? 2.5" Exhaust with Magnaflow high flow cat
Power goals? 300HP
Car goals? Weekend/summer car, but decent power for reliability
Power goals? 300HP
Get a Garret T3/T4 .50 or .57 trim turbo. May be able to find it with the 5 bolt exhaust housing and use the same downpipe. If not, a simple conversion to 4 bolt or Vband would get you on track.
You'll probably want bigger injectors too. They look very small.
Find one of these:
http://www.go-autoworks-store.com/gat345tr.html
Used would save you some bucks.
Find one of these:
