Honda Wheel Bearings and Hubs (Where to Buy)
Hello,
I'm looking to order new front hubs with the wheel bearings already installed. I looked up parts on Honda Parts Now and came up with the two below links. I'm trying to find bearings that accept the 1990 Si Axles (EF Hatchback) which I believe are 26 spline.
Front Bearing Hub assembly #1) 44300-SB2-963 - Genuine Honda Bearing Assy., FR. Hub (Koyo Seiko)
Front Bearing Hub assembly #2) 44300-SB2-965 - Genuine Honda Bearing Assy., FR. Hub (Toyo Seiko)
Regards,
Nick
Regards,
Nick
Re: Honda Wheel Bearings and Hubs (Where to Buy)
Only way i know to have hubs already pressed into the bearings is to gey a complete knuckle assembly.
If you if you actually take a look at that parts diagram when it shows is that is that you must press the bearing in the knuckle and says that ring and then you must press the Hub into the bearing. If The Hub is already pressed into the bearing it would be impossible to put the snap ring on
Bnjmn
09-20-2005 03:43 PM
