what is the the difference between the JR M-45 and M62?
Old Jul 8, 2001 | 06:27 PM
Peter K's Avatar
New User
Default what is the the difference between the JR M-45 and M62?
what is the the difference between the JR M-45 and M-62? do i need to specify which one i want when i order? sheesh. i thought that there was only one JR kit for my 96 ls.
Old Jul 8, 2001 | 07:00 PM
boomslang's Avatar
Default Re: what is the the difference between the JR M-45 and M62? (sxychnamn)
The M62 pushes alot more air. That is the one you want probably.
Old Jul 8, 2001 | 07:53 PM
TurboInteg95's Avatar
the 62 moves more cfm, you'll want that one.
Old Jul 8, 2001 | 08:17 PM
Peter K's Avatar
New User
Default Re: what is the the difference between the JR M-45 and M62? (TurboInteg95)
i talked to some guy and he said there is only one kit for my ls. do i need any mods for it to work well or is the stock exhaust and fuel injectors ok for the time beign while i save up money. thanks
Old Jul 9, 2001 | 06:02 AM
E Swift's Avatar
I work for Eaton, and, the difference is simple. We make 4 different models of superchargers. It depends on how strong of a motor you have. We make supercharger for Mercedes Benz cars, and since there cars have much much larger than our 4 banger cars, they require the larger supercharger. The M62 Eaton supercharger is for motors that are 2.0-2.5 liters, OR, motors that can withstand the extra power. The B18C GSR motor is obviously a 1.8, but, its strong enough to use the M62 Charger.
I hope this helps.
Old Jul 9, 2001 | 07:01 AM
Ubermensch's Avatar
Default Re: what is the the difference between the JR M-45 and M62? (420TegLS)
But, he has the B18B. The M62 won't fit without modifications, and those that have made the changes didn't see that drastic of an improvement. The M45 is what was intended for the B18b.
Old Jul 9, 2001 | 11:09 AM
E Swift's Avatar
Default Re: what is the the difference between the JR M-45 and M62? (Ubermensch)
But, again, you must understand that the B18B doesn't put out as much power as the B18C, therefore, it might not be able to withstand the M62. Each supercharger is specifically designed to work on specific motors.
Yes, I understand the B18B and B18C heads are designed differently. But, when we build these, we don't build them to fit Jackson Racing needs. We build superchargers mainly for Mercedes, Jaguar, etc. etc. Jackson Racing comes to us, and, asks to purchase our design. Whatever Jackson does after that, is there decision. We only supply the Supercharger. We do not give them the 6lb pulley, or anything else that requires a modification to fit it onto a Honda motor.
So, my advice to you is to talk to Jackson Racing regarding which one is best for the B18B. Only they would know that answer for you. Eaton only builds them, and then they sell them to Jackson, and then Jackson slaps on their name to it. Jackson is just a small client of ours, compared to the large Car companies around the world.
Old Jul 9, 2001 | 11:38 AM
Peter K's Avatar
New User
thanks for the info 420tegls. that helped a lot. i was going around for a while asking people if they had the m62 for the b18b. i guess they think that i'm a dumbass now. oh well. i guess i'll just have to get the m45. thanks
Old Jul 9, 2001 | 01:09 PM
zip's Avatar
zip
Hey 420TegLSm, did you know that the 99-00 Civic (1.6 DOHC VTEC) JRSC kit also has the M62 Eaton charger? All the JRSC kits for VTEC, B series, engine have the M62 Eaton charger.
Old Jul 9, 2001 | 07:14 PM
Marc's Avatar
Default Re: what is the the difference between the JR M-45 and M62? (zip)
All the DOHC VTEC JR kits utilize the M62 blower. I think this is necessary due to the higher redline of the engine. Can you imagine spinning an M45 to 8200rpm? I wonder if JR utilizes the larger blower to help compensate for the blow thru when VTEC activates? Any comments?
Old Jul 9, 2001 | 09:51 PM
HX_Guy's Avatar
Default Re: what is the the difference between the JR M-45 and M62? (Marc)
What blower does the CRV charger use?
93 Eg Couper
Jan 25, 2009 06:38 AM
j_kevin_ca
Aug 14, 2007 06:38 PM
aandrewcc
Jan 12, 2006 12:34 AM
ChaseIntegra
Sep 23, 2003 08:07 AM
RiceInjectedCivic
Nov 20, 2002 03:14 PM
