WHITE SMOKE!!!!
Old Jun 27, 2001 | 09:44 AM
veejay's Avatar
New User
Default WHITE SMOKE!!!!
Intermittent white smoke out of tailpipe... could it be a blown head gasket? Is there a way to tell? It's not always smoking. Only once in a while. Car runs fine... not boosting until I find out whats wrong. Overheating also. Will this cause damage to engine if not corrected ASAP? What about temporary repairs... like a can of block seal that is poured in the radiator and cycled through the engine to seal any leaks? Any opinions? Experiences? Solutions?! Thanks! 1993 LS Turbo, Stock B18A
Old Jun 27, 2001 | 09:46 AM
BowSeR's Avatar
New User
Default Re: WHITE SMOKE!!!! (veejay)
prolly a blown turbo mine did that for awhile it would smoke then stop and smoke agian. most likey i would say its a seal on your turbo
Old Jun 27, 2001 | 09:49 AM
veejay's Avatar
New User
Default Re: WHITE SMOKE!!!! (BowSeR)
no coolant lines running through the turbo... just oil lines. wouldn't that cause blue smoke if it was oil burning? hmm...
Old Jun 27, 2001 | 09:58 AM
BowSeR's Avatar
New User
yeah my turbo did the same thing
Old Jun 27, 2001 | 07:20 PM
johng's Avatar
White smoke = coolant.
Especially with your overheating symptom, it looks like a head gasket problem. Just had mine let go, so I know the smoke. Have a leak down test done to be sure.
Old Jun 29, 2001 | 01:55 PM
MatT3T4's Avatar
Default Re: WHITE SMOKE!!!! (johng)
do a compression test first, then do a leakdown test...if your head gasket were cracked, it would probably be a lot more smoke than you describe, but it still sounds like that may be the culprit, so do the tests
oranginal
Apr 28, 2012 05:35 PM
trus01d1er
Apr 27, 2009 05:35 AM
torqueless
Oct 29, 2005 02:59 PM
bretx0r
Aug 8, 2002 08:13 PM
sushibug
May 30, 2002 03:04 PM
