code 3 anybody with 2k steady RPMs
Old Jul 5, 2001 | 02:56 PM
synergy004's Avatar
Default code 3 anybody with 2k steady RPMs
damn motor, LS built from bottom up with my custom turbo set up is throwing a code 3. IT idles at 2k RPM constant and wont seem to lower itself even after long idle period. I tried lossening the throttle cable and adjusted the screw on the TB, still didnt work, then tried adjusting the damn distributor but that only made it go to about 1800 RPM still steady there. Any other suggestions. Thanks
Old Jul 5, 2001 | 03:33 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: code 3 anybody with 2k steady RPMs (synergy004)
I think Code 3 is a MAP sensor problem. Im about 90% sure that is what the code is. check out the connection of the map sensor and see if its ok.
art
Old Jul 5, 2001 | 03:58 PM
synergy004's Avatar
Default Re: code 3 anybody with 2k steady RPMs (Arturbo)
art it is the map sensor seal, i did try cleaning the connectors and stuff and even tried another map sensor from my old motor. Damn things still idles friggin high though around 2k steady.
anyone have this prob, i crrently dont have the O2 sensor hooked up, could this cause it
Old Jul 5, 2001 | 04:04 PM
Arturbo's Avatar
Better than steak
25 Year Member
Are you sure that you're not throwing more than one code? check the code again because you might have more than one. Does the idle bounce or does it stay high?
Check you IAC or the fast idle thermal valve.
art
Old Jul 6, 2001 | 08:16 AM
FAST94GSR's Avatar
New User
I'd say IAC valve. I had a similar idle problem but I didn't throw a code.
Old Jul 6, 2001 | 11:45 AM
synergy004's Avatar
Default Re: code 3 anybody with 2k steady RPMs (FAST94GSR)
I will chech the IAC which is a code 14, but the only codes i throw is one for the O2 sensor which I kow why since its not on there and a code 3 which is the map sensor. I think I will try replacing the TPS and see whatsup with the damn thing.
thanks guys
TRYLSTEG808
May 28, 2007 07:40 PM
93sidelsolvtec
Jan 28, 2007 11:58 AM
Achenar
Oct 2, 2004 01:45 PM
ILLICON3000
Aug 4, 2004 03:25 PM
synergy004
Jul 5, 2001 07:10 PM
