HKS EVCIV Help!
Old Jul 4, 2001 | 01:02 PM
Ray's Avatar
Ray
New User
Default HKS EVCIV Help!
I have a HKS EVCIV and dont have a manual. I have no idea how to use it and dunno how to program it.
[Modified by Ray, 10:02 PM 7/4/2001]
Old Jul 4, 2001 | 08:12 PM
Drag3GSR's Avatar
New User
Default Re: HKS EVCIV Help! (Ray)
um what do you need to know how to do?
to program it you need to get it in learn mode... the first time you turn it on it will go into learn mode... if you need to relearn it, turn it off, turn it back on, then you have to press 3 of the 4 buttons at the same time (i forgot which ones right now, but I think the power button is the one not pressed) you hold them for a second, them let go and i think the screen says "L" then...
you are in learn mode... drive down a straight flat road without hitting boost untill 3rd gear, once in 3rd, punch it all the way untill redline. I think the screen will say P now... repeat the above process... the boost will raise a little this time...
now it is learned... if you did the above steps perfect, the boost should be perfect that you set it at... if you didnt do it perfect you will need to "trim" it up or down a little...
after you get that far, if you need help with the trim adjustment email me at DKluck@Austin.RR.com and I will help you
Old Jul 4, 2001 | 08:19 PM
Dee's Avatar
Dee
You need to contact HKS USA or a local dealer!
You will need to do three good 3rd gear passes while the car is in the learn mode. If everything is OK you will be able to adjust boost and set the scramble boost from that point.
Get the instructions!!
ACrite3404
Sep 23, 2007 01:28 PM
yellowturbo
Sep 18, 2006 05:23 AM
ryu12341
May 14, 2003 02:19 PM
311
Jul 12, 2002 01:46 PM
