help! stuttering
Old Jul 3, 2001 | 09:51 PM
veejay's Avatar
New User
Default help! stuttering
after taking the head off my b18a and then putting everything together again, i start the engine and it is a very rough idle, dies, only stays on when i give it gas, and stutters bad while doing so. checked all my vac hoses and those are fine.... timing was set to stock also.... could it be that my TDC was off??? how can i correct??? thanks
Old Jul 3, 2001 | 10:03 PM
LsTurbo91's Avatar
Default Re: help! stuttering (veejay)
check the cam gears and crankshaft are lined up then check timing, don't you have a helms manual, I hope you do? Did you also adjusted your valves to spec?
Old Jul 3, 2001 | 10:40 PM
TurboInteg95's Avatar
your cam timing is probably off. set the crank to TDC and the cam as well and then put the timing belt on.
Xscort
36
Jul 25, 2007 05:32 PM
stevescivic
Sep 6, 2006 10:02 PM
-singlecamkillr
Apr 20, 2005 11:20 AM
PatrickGSR94
Apr 11, 2003 04:21 PM
