vtec to non vtec, what internals will crossover??
Old Jun 27, 2001 | 12:53 AM
paulzy's Avatar
Default vtec to non vtec, what internals will crossover??
what will actually cross over from a vtec shortblock into the non vtec block that will actually help it out? I know for sure the oil pump fits, but what about the water pump, block girdle, pump pickup, baffle, yadda yadda...
Old Jun 27, 2001 | 10:26 AM
TurboInteg95's Avatar
Default Re: vtec to non vtec, what internals will crossover?? (Slow_ass_4dr)
the water pump is interchangeable, the GSR pump has more teeth on it then the LS one so it actually spins less. block girdle is not interchangeable and I dont see any advantage to the pickup and baffle but I could be wrong. pistons, crank, and rods are all interchangeble. rods and crank have to stay together but the pistons can be used on LS rods no problem. the dipstick is probably interchangeable as well.
Old Jun 27, 2001 | 10:37 AM
paulzy's Avatar
Default Re: vtec to non vtec, what internals will crossover?? (TurboInteg95)
so which timing belt will I have to use for a gsr water pump in an ls block?
Old Jun 27, 2001 | 10:48 AM
GSR timing belt
Old Jun 27, 2001 | 11:06 AM
b18bturbo's Avatar
pretty much everyting is interchangeable except the girlde. The oil squirters can be machined into a ls block. if you want the girdle contact z10eng. they have them The water pump and the oil pump are good to swap out to the ls. Especially if you are doing a Ls .vtec swap
Jeanious
Aug 3, 2007 09:09 AM
k20o2o4civic
Aug 30, 2006 01:12 AM
bens_redeg
Jul 10, 2004 07:11 AM
ILOVEGIRLS
Sep 30, 2002 11:07 PM
