Are FMU's necessary if you have big injectors, fuel pump, and a AFC?
Do you have to use an FMU once you upgrade to lets say 370's? If so then an 8:1 should be used?
Thanks in advance,
EVIL
Thanks in advance,
EVIL
Re: Are FMU's necessary if you have big injectors, fuel pump, and a AFC? (b18bturbo)
A regula fuel regulator will always be used. I am just asking if the FMU is necessary and if 8:1 pill is the one to use with 370's.
EVIL
EVIL
Re: Are FMU's necessary if you have big injectors, fuel pump, and a AFC? (Evil GS-R)
it all depends on your car. I used a 6:1 with a special controller i designed to work of the map sensor. All cars will act different. So start high and work your way down.
Where can i get those pills to use with the vortech fmu? I have been looking but no luck.
EVIL
EVIL
New User
An fmu will help provide a nice ratio at all rpms vs. tuning for top end or mid range. You'll obviously need a lot more fuel at 6k than at idle, so if you want performance everywhere you'll need the fmu.
jackhunt321
09-06-2005 04:32 PM
