Can I keep A/C with a Revhard Turbo Manifold?
Old 07-03-2001, 11:16 AM
Tr0LL's Avatar
Default Can I keep A/C with a Revhard Turbo Manifold?
I'm piecing together a turbo kit. I was only looking for a DRAG manifold at first because I hear their manifold was the only manifold that was a/c compatible. But now I read that the revhard is compatible with a/c also.
Anyone know for SURE if the revhard is a/c compatible? if it makes a difference, i have a 90 integra. Also if possible, do u guys know of any other manifolds that are a/c compatible? Thanks!!!
Old 07-03-2001, 11:21 AM
Smashback's Avatar
Default Re: Can I keep A/C with a Revhard Turbo Manifold? (Tr0LL)
I have the RevHard manifold for my D16, and it's TINY. No problem with AC clearance here ...
Old 07-03-2001, 05:05 PM
Tr0LL's Avatar
Default Re: Can I keep A/C with a Revhard Turbo Manifold? (mplex2000)
i got this email from Rev-Hard..... now i ask again..... are you SURE you can use A/C in a 1990 integra???
"Yes this will fit your engine, but the problem is the chassis of your car. Your car doesn't have enough room for the a/c compressor not like the 94 and up models."
Old 07-03-2001, 05:53 PM
Ben Huynh's Avatar
If you received confirmation from the manufacturer, what more do you need?
Old 07-03-2001, 06:55 PM
Tr0LL's Avatar
Default Re: Can I keep A/C with a Revhard Turbo Manifold? (ben@importparts.com)
because i'm putting together a custom kit..... which means i will be doing custom piping.....
i've heard a few ppl on the g2ic board that it's possible as long as i do the piping right..... just getting more feedback.... that's it....... if it's too hard, i'll just get a drag...... if it's not..... then i'll get the revhard......
Old 07-03-2001, 07:41 PM
LsTurbo91's Avatar
Im about to put mine back ... We have very little clearance... but it will work. You have to buy fal fans or some sort that is thinner than stock. The power steering line in front of the car is also gonna be in the way.
[Modified by 9psiLsT, 8:42 PM 7/3/2001]
BlackEG6
12-11-2005 01:27 AM
Cractos
04-01-2004 09:42 AM
specie
09-19-2002 01:57 PM
not7fifteen
06-14-2002 01:58 PM
veejay
09-05-2001 07:49 PM
Quick Reply: Can I keep A/C with a Revhard Turbo Manifold?
