help..turbo install threw engine code
Old Jul 6, 2001 | 06:35 AM
newsense's Avatar
New User
Default help..turbo install threw engine code
i installed a revhard turbo on my 94 acura integra ls....i also rebuilt the motor(all new stock parts)....
i am getting code 43......which is "FUEL SUPPLY SYSTEM". The book says to check vacuum lines and fuel lines...so i did that and it didnt go away
could this be my stock fuel pump...i am currently running the msd inline fuel pump and vortech fmu......
Old Jul 6, 2001 | 07:23 AM
00 Si's Avatar
New User
Default Re: help..turbo install threw engine code (newsense)
What kind of boost are you running and did you buy upgraded injectors? A Vortec FMU without injectors is like pourting a gallon of water through a straw.
Old Jul 6, 2001 | 08:51 AM
newsense's Avatar
New User
Default Re: help..turbo install threw engine code (00 turbosi)
i havent even boosted on it yet......im still trying to break in the motor...ive heard that this code means you are running extremely rich...my a/f gauge stopped working so i dont really know.....the car doesnt seem to be acting funny, but then again i havent taken it over 4k rpm.....any suggestions??
Old Jul 6, 2001 | 11:37 AM
dustin's Avatar
I run the Vortech FMU with stock injectors. It works just fine. The entire idea behind the Vortech 12:1 FMU is that it is to be used with stock injectors. If you had a way to control larger injectors, you would not need the FMU in the first place.
Dustin
ALL MOTOR EM2
Nov 27, 2007 12:50 PM
spoon95eg
Dec 19, 2005 06:15 PM
ityab0y
Jan 25, 2005 12:31 PM
wrXtian
Nov 29, 2002 10:41 PM
SIK IN DA HED
Sep 28, 2002 12:57 PM
