mf2 tuning?
Old Jul 5, 2001 | 03:17 AM
sagaprelude's Avatar
Default mf2 tuning?
does anyone know how to use the mf2 that came with the fmax kit? or do i need to use it only when dynoing??
Old Jul 5, 2001 | 05:20 AM
DirtyLude's Avatar
Default Re: mf2 tuning? (sagaprelude)
Open it up, turn the dials.
http://www.aquamist.co.uk/cp/mf2/techmf2/mf2tec.html
It's not hard. I ended up lowering the activation point and leaning the whole thing out some. It comes from F-Max set pretty rich.
Old Jul 5, 2001 | 04:53 PM
Default Re: mf2 tuning? (DirtyLude)
thats it? you just turn *****? all 8 of em?? anything else i need to do??
Old Jul 5, 2001 | 07:58 PM
liam821's Avatar
25 Year Member
naw naw. thats about it. You just turn little *****. If i recall, clockwise is more fuel, and counterclockwise is less fuel.
I bought the mf2 new and had to tune it myself..i just turned it up really high and hit the gas. Way to rich..turned it down a little..and did another test. I used a shitty AutoMeter A/F ratio gauge to get an idea about how rich/lean it was running.
But you can tell when you have it set right..the car pulls strong..doesnt bog down at low rpms or go lean and detanate at high rpm.
Make sure you keep your ears open for detination. Cuz that will kill your engine if you do it for too long...
liam
Old Jul 5, 2001 | 08:10 PM
Default Re: mf2 tuning? (liam821)
thanx everyone, do i need to turn all the *****?
Old Jul 5, 2001 | 08:31 PM
mike2016's Avatar
New User
How does detonation sound like?? I can't hear anything except the wastegate sound.... will the car act different if its detonating?
[Modified by mike2016, 9:31 PM 7/5/2001]
Old Jul 5, 2001 | 11:40 PM
Default Re: mf2 tuning? (mike2016)
does anyone know what it means when the car will have a problem starting? like sometimes ill bog
Old Jul 6, 2001 | 07:58 AM
Smashback's Avatar
Bogging - maybe too rich? Detonation sounds like clicking/clacking coming from the motor, you can hear it under acceleration usually.
raverx3m
Engine Management and Tuning
Jun 4, 2013 03:27 PM
prelude_problems
May 30, 2009 06:21 PM
tunedek
Aug 22, 2006 08:39 PM
freeplay
Sep 19, 2002 03:49 PM
HarryB
Mar 28, 2002 08:05 AM
