need help check engine on greddy turbo kit
I had the biggest problem..i installed a greddy turbo on my 98 gsr and i put the injectors in but not the blue box and start the car for 5 mins and move it inside my garage and all of a sudden my check engine went on..i check the code 72 and it says random misfire or misfire detected...but the when i finished the job the car runs perfect except the check engine is still there...can someone help me with this i would really appreciate all the feedback...www.smkngsr@aol.com
Re: need help check engine on greddy turbo kit (smkngsr)
reset your ECU to remove any previous CELs. If they come back, the problem still exists. A CEL will stay displayed until you have gone through 3 full warm up cycles, then it will go away if the problem is goen. HTH Chris
that happened on a 98 gsr that I installed a greddy kit on, it just went away by itself after a month or so.
