How do i adjust my GReddy Tpye S BOV?
How do i adjust my GReddy Tpye S BOV? Don know how to do this, want to learn...can someone please help me with this? What is too much, what is not enough?
Re: How do i adjust my GReddy Tpye S BOV? (greyzone)
usually you can keep it wide open, but first take the car out and hold it at full boost, if it says at your base setting then its fine...however if the boost drops then go back and adjust it....back it out towards the soft setting. HTH.
New User
Re: How do i adjust my GReddy Tpye S BOV? (98hx99b18c)
i ahve a question to, where should my vacumm line from my bov go to. i think it goes somewhere to the intake manifold, but where. i just put my greddy kit on.
New User
Re: How do i adjust my GReddy Tpye S BOV? (newsense)
i dont think i follow that. what you are saying is i connect it to the line going to my fuel pressure regulator? i dont think that makes sense. can someone elaborate more
Re: How do i adjust my GReddy Tpye S BOV? (clean)
What that means is Tee off the vacuum line from your fuel pressure regulator to the bov vacuum line....cut the vacuum line of your fpr and then place a tee in there, hook one end to the bov vacuum line and then reconnect the other side of the fpr vacuum line that you cut. HTH
