Buiding a 12sec.daily driven 90civ hb
Does anyone have thoughts on this set-up:
Car: 88-91 civ hb
engine: b16
sleaves:iron
pistons: je
rods: eagle/endyn
bearings: stock
rings:?
balanced and blueprinted
head: b16 ported
cams?
turbo: turbonetics?
intercooler: spearco(sp)
Susp: ground control
ect... to make the car into a race/street car
This is being built by us for us we are road racers who want more exposure
for the buisness Thanks
trans: fresh and cryo-treated syncros and gears
Car: 88-91 civ hb
engine: b16
sleaves:iron
pistons: je
rods: eagle/endyn
bearings: stock
rings:?
head: b16 ported
cams?
turbo: turbonetics?
Re: Buiding a 12sec.daily driven 90civ hb (SoloSol)
man , thats a project...u want sumthing fast and driven daily , try a H22 in ur car and 75 shot nitrous...ur in 12's...
New User
built b16 in a 90 hatch... 14-16 psi with a drag or revhard kit will put you in the low 12's... I run 12.1 @ 116 /w 16 psi in a full body GSR... that hatch should be like 400 lbs lighter
This sound good! Keep it coming!!! Any suggestions on components, parts for the build-up?
New User
suggestions? http://www.Hondata.com With a b16, hondata, large (440 or 550cc) injectors, and an adequate supporting fuel system, you should be able to safely run 12-18psi, with more than enough HP to get you into the 12's so long as you have slicks. I would also recommend a limited slip differential like a Quaiffe.
you can run a zdyne in that car. I have seen ef's run 13's with just a gsr swap and a stripped interior. It will not take much to get that car into the 12's
Solosol.....that sounds good man. Sounds almost exaclty like what I have. I have a 90 civic HB with a turbo gsr motor. Anyways....your setup sound good......but I would SERIOUSLY recommend taking VaporTrails advice on that Hondata. If you are trying to keep this a daily driver and reliable....The hondata is worth the money. Tune your car to unimaginable levels......and safe. John has been tuning for too long and knows what it takes for a daily driver.
LEt me know if you need help-......Blown-civic@att.net
Jason
Jason
