ZEX AND ENGINE PROBLEMS?
Old Jun 29, 2001 | 11:29 AM
350z-tech's Avatar
Default ZEX AND ENGINE PROBLEMS?
man i had my zex insalled on my 2001 ITR at a friends professional shop, and today when i went to go to the bank and on the way back i notice the green key light coming on and it seems like the engine shuts offf and back on again, ITS WIERD!! its like a jerking motion and then bam it comes back on . the guy from the shop came to my house and looked at it and told me there was no way it could be from the nitrous, the idleing is fine and no knocking noises. he said it could be the cars anti theft system ******* somehting up. well, any suggestions?
thx
Old Jun 29, 2001 | 11:37 AM
GSRwBOOST's Avatar
Default Re: ZEX AND ENGINE PROBLEMS? (ihiustler)
remove the wire tap for the tps sensor (that tells the zex box that your at wot) and drive it around and see if problem persists.. it could have a bad connection and be messign with the tps... ??
does idle drop also when this happens?
compression test (even though it idles find)??
what shot and how much has been used so far (nitrous)??
was the timing messed with?
Old Jun 29, 2001 | 11:41 AM
350z-tech's Avatar
Default Re: ZEX AND ENGINE PROBLEMS? (GSRwBOOST)
i am only running a 55 shot and i diconected the zex completely and it still does it, the green key light comes up so i dont know what it could be, it only has 3000 mile on it
Old Jun 29, 2001 | 11:46 AM
GSRwBOOST's Avatar
crazy question.. but which green light.. (sorry i only have a GSR) are you referring to? If you have no other mods... take that bad boy down to the dealer and ask them to look at it.. i'm sure it's under warrenty, just dont have aftermarket parts on it.. but then again they have to prove it was something on the car..
have you unplugged the battery and let the ecu reset itself?
honestly.. no other mods... (remove the zex kit) and c the dealer...
Old Jun 29, 2001 | 12:30 PM
350z-tech's Avatar
aem cai b&m fpr commando flow and thats about it and the zex
CivicHatchback14
Sep 1, 2004 11:38 PM
thrombosis
Sep 25, 2001 11:02 AM
350z-tech
Jun 29, 2001 05:03 PM
350z-tech
Jun 29, 2001 12:29 PM
PolosportZ81
Jun 21, 2001 04:58 AM
