how should i build up my motor?
i have an LS engine in a civic....i purchased a revhard turbo and i want to know whut i should purchase to build up my motor to run 12s....thanx all for da help!!!
Re: how should i build up my motor? (Suprdave)
first i would build the motor and then get standalone ecu with some larger injectors.
you should be okay in that setup good enough for some 11/10s cut some wieght and be even faster.
Re: how should i build up my motor? (b18bturbo)
and then spend another $$$$ on the suspension.
get some slicks and make sure you have extra sets of axles.
high 11's shouldn't be a problem for you with an ls in a civic, turbo and built motor. high 11's that is.
