Holley (Walbro) fuel pump question
Old Jul 6, 2001 | 09:11 PM
00 Si's Avatar
New User
Default Holley (Walbro) fuel pump question
I bought an Holley (Walbro) fuel pump and I thought it was an 255lph, but I looked at the side and it says typical flow 120lph@300kPa. Did I get giped or what? On the box it says New Forced Induction Design. Part number12-916. I looked it up on Holley's web page but it wasn't there. Can anyone please help. Thanks
Old Jul 6, 2001 | 11:16 PM
RTEK's Avatar
New User
Default Re: Holley (Walbro) fuel pump question (00 turbosi)
fuel pump delivery rate is advertised and rated according to the output LPH/GPH at a given fuel pressure setting EX: 255LPH at 45 PSI. Holley makes 2 different 255LPH pump the other one is designed for forced induction use. and to verify that you may/may not have a problem you have to call Holley Tech Support Dept and have the F/P part # handy
Old Jul 8, 2001 | 01:32 PM
boosted97's Avatar
New User
Default Re: Holley (RTEK)
I got the same pump and if i remember correctly the test was on a Mustang so I doubt it is the same pump. I just put it in and it seems to have solved the problem I had. I was running a JR pump and it was getting lean at 6K.
Old Jul 8, 2001 | 01:42 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Holley (boosted97)
I wouldnt trust any walbro pump on a turbo car. It would have to be the bosch pump. Ive seen 2 walbro pumps that were not able to keep up with the high fuel pressure that we get by using an fmu. I assume you are using a FMU. If not then the walbro will be ok...
arr
ezark
Jun 10, 2006 12:41 PM
confyused
Apr 6, 2005 03:31 AM
1 2 NV
Sep 4, 2002 12:44 PM
