Built 94 LS with 12psi, are 370cc injectors too much????
New User
Hey all you boost masters out there, I have a Built 94 LS, sleved, crower rods, JE 8.5:1 pistons, S-AFC, Vortech FMU, MSD 6AL, NGK cold plugs, AEM fuel rail and filter, Holly fuel pump, blah....
Anyways, will I be able to tune the 370cc injectors on 12psi and still be able to drive it on the street at lower rpms??? I have a feeling I'll be bogging out at stop lights and stop and go if I don't keep it in the high rpms?
Right now I'm only running 6psi on stock injectors, but I'm going to crank it after a few more miles are on the new engine. Thanks!
Re: Built 94 LS with 12psi, are 370cc injectors too much???? (BlowOff)
USE your safc to tune the injector down. You should be okay with that.
Shocka1998LX
03-16-2004 04:45 PM
