Honda Fuel pump pressure and flow test results.
Last week we tested a Honda Civic 2000 fuel pump and found that the more pressure you ran, the less fuel it delivered.
At 35 psi, the stock fuel pump could deliver enough volume of fuel for 400hp, but at 75 psi, it could only deliver enough fuel for 200hp.
This has implications for the use rising rate rate regulators.
Check out the full analysis at http://Hondata.com/techfuelpump.html
[Modified by Hondata, 2:22 AM 7/9/2001]
Re: Honda Fuel pump pressure and flow test results. (Hondata)
Thanx Doug, but are U saying that If one is running up to 400 Hp an aftermarket is not needed?
Its info like this and forward thinkers that will help this sport to evolve successfully, thanx again
Re: Honda Fuel pump pressure and flow test results. (Liltrix)
I think it is safe to say that almost all people running RRR setups are using either a replacement or auxilary fuel pump, though.
Dustin
Dustin
streetrage
07-04-2006 11:09 PM
